[GRASS-user] fatal error: 'libintl.h' file not found (OSX)
William Kyngesburye
woklist at kyngchaos.com
Wed Oct 15 06:43:06 PDT 2014
Right, so we're back to the problem, if libintl.h is bundled in the GRASS app include dir, why isn't it found? I just looked, yes it's there, in the right place, it should work.
Svein, is there more before the error? I'm looking for a line that starts with 'gcc' or 'clang'.
On Oct 15, 2014, at 1:08 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 15, 2014 at 1:57 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I do bundle it in my GRASS binaries.
>> My point is that there is no functional reason that internationalization (which is otherwise optional in configuration for GRASS) should be needed to compile r.stream. extract.
> But don't you compile with --with-nls support? Then it is needed as it
> is for most other commands which come with gettext enabled messages.
>>>> On Oct 12, 2014, at 3:23 PM, Svein Harald Sønderland <snarrald at gmail.com> wrote:
>>>>> Anyone know how to get the r.stream addons to work on mac??
>>>>> When trying to install I get this error:
>>>>> /Applications/GRASS/GRASS-6.4.app/Contents/MacOS/include/grass/glocale.h:9:10:
>>>>> #include <libintl.h>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
