[GRASS-user] v.in.geonames not importing txt file in GRASS 7.0.0beta3 Windows
Helmut Kudrnovsky hellik at web.de
Wed Oct 15 01:34:04 PDT 2014
Markus Neteler wrote
> On Fri, Oct 10, 2014 at 11:53 AM, RichardCooper <
> richtcooper@
> > wrote:
>> Hi,
>> I'm getting the following error on attempting to import geonames into
>> GRASS
>> 7.0.0beta3 on Windows7.
>> I've tried to import via the GUI and command console without success.
>> However, it does import with GRASS 7svn[57721] on Linux.
>> Richard
>> (Fri Oct 10 16:47:43 2014)
>> v.in.geonames input=C:\Users\rcooper\Desktop\TH.txt output=geonames_th
>> Converting 171472 place names...
>> cat: =0: No such file or directory
>> cat: output=geonames_th: No such file or directory
>> cat: y=5: No such file or directory
>> cat: input=C:\Users\rcooper\grassdata7/chula_4326/asiapoptha
>> i/.tmp/unknown/408.0: No such file or directory
>> cat: columns=geonameid integer,name varchar(200),asciiname
> I have tried with current 7.0.svn using
> http://download.geonames.org/export/dump/TH.zip
> and did not face any problems (on Linux). The Python indentation was
> probably not right (fixed in SVN) but I think that this won't matter.
> I wonder if the internally used separator "|" may cause the issue?
> Perhaps the internal v.in.ascii call should simply be done with the
> existing tabs?
> A Windows user is needed to explore that...
> Markus
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
tested here with
GRASS Version: 7.1.svn
GRASS SVN Revision: 62255
Erstellungsdatum: 2014-10-15
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
v.in.geonames --verbose input=C:\tmp\TH\TH.txt output=th
Converting 236734 place names...
Using native format
Scanne die Eingabe zur Ermittelung der Spaltentypen...
Maximale Länge der Inputzeile: 1998
Number of columns: 19
Column: 1  type: integer
Column: 2  type: string length: 114
Column: 3  type: string length: 102
Column: 4  type: string length: 1885
Column: 5  type: double
Column: 6  type: double
Column: 7  type: string length: 1
Column: 8  type: string length: 5
Column: 9  type: string length: 2
Column: 10  type: string length: 2
Column: 11  type: integer
Column: 12  type: integer
Column: 13  type: integer
Column: 14  type: integer
Column: 15  type: integer
Column: 16  type: integer
Column: 17  type: integer
Column: 18  type: string length: 14
Column: 19  type: string length: 10
WARNING: Spalte Nummer 11 <admin1code> ist als string definiert und hat nur
Integer-Werte.
WARNING: Spalte Nummer 12 <admin2code> ist als string definiert und hat nur
Integer-Werte.
WARNING: Spalte Nummer 13 <admin3code> ist als string definiert und hat nur
Integer-Werte.
WARNING: Spalte Nummer 14 <admin4code> ist als string definiert und hat nur
Integer-Werte.
WARNING: Spalte Nummer 16 <elevation> ist als string definiert und hat nur
Integer-Werte.
Importiere Punkte...
Fülle Tabelle...
Erstelle Topologie für die Vektorkarte <th at test>...
Registriere Primitive...
236734 primitives registered
236734 Vertices registriert
Erzeuge Flächen...
0 areas built
0 isles built
Füge Inseln hinzu...
Füge Zentroide hinzu...
Die Topologie wurde erstellt.
Anzahl der Knoten: 0
Anzahl der Primitive: 236734
Anzahl der Punkte: 236734
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
seems to work here.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-in-geonames-not-importing-txt-file-in-GRASS-7-0-0beta3-Windows-tp5166832p5167599.html
Sent from the Grass - Users mailing list archive at Nabble.com.
