[GRASS-user] r.drain stops after short segment
cmshobe charles.shobe at colorado.edu
Tue Oct 28 09:19:41 PDT 2014
Hi all,
I am using r.drain with an elevation raster as input. I filled the elevation
raster using r.fill.dir. When I run r.drain, it only creates a short path
segment before finishing the analysis, even though it hasn't come close to
the region border. There should not be any sinks in my elevation raster
because I filled it. Does anyone have any experience with this problem?
Thanks!
Charlie
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-drain-stops-after-short-segment-tp5170003.html
Sent from the Grass - Users mailing list archive at Nabble.com.
