[GRASS-user] Returning values to Python
Kevin Williams
zs1kwa at gmail.com
Fri Oct 31 00:18:28 PDT 2014
Thank you all!
Cheers, Kevin
On 30 October 2014 10:38, Pietro <peter.zamb at gmail.com> wrote:
> On Thu, Oct 30, 2014 at 8:04 AM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>>> One of the documentation pages mentioned a function "stdout2dict" from
>>> "grass.pygrass.modules", but it does not look like this is in the
>>> pygrass package any longer?
>> If you use grass.script.raster_what(), it returns a list of
>> dictionaries.
>> AFAICT, PyGRASS requires you to add stdout_=PIPE, then you can get the
>> output as a string from module.outputs["stdout"].value.
> or simplier: module.outputs.stdout
> or using directly the C API through python with:
> from grass.pygrass.vector import VectorTopo
> from grass.pygrass.raster import RasterRow
> from grass.pygrass.gis.region import Region
> with RasterRow('elevation', mode='r') as rast:
> with VectorTopo('hospitals', mode='r') as hospitals:
> region = Region()
> for hosp in hospitals:
> value = rast.get_value(hosp, region)
> if value is not None:
> print(hosp.cat, value)
> Pietro
