[GRASS-user] Unable to use Command Line Access to GRASS-GIS
Artur Bercik
vbubbly21 at gmail.com
Fri Oct 31 08:20:18 PDT 2014
Dear Vaclav Petras:
Thanks for your answer, and sorry for cross posting.
I am thinking of accessing the grass command line through
"C:\OSGeo4W\bin\grass70.bat" using python subprocess.call
Are you familiar with this one?
On Fri, Oct 31, 2014 at 11:54 PM, Vaclav Petras <wenzeslaus at gmail.com>
wrote:
> On Fri, Oct 31, 2014 at 5:10 AM, Artur Bercik <vbubbly21 at gmail.com> wrote:
>> Dear Pietro
>> Thanks for your support with the codes for the bat file.
>> I saved it as .bat file, and double clicked on it.
>> Is it enough to change the system variables?
>> Pietro might know better, but you have to set the variables for the
> process which needs them. You have to invoke the GRASS modules in the BAT
> script which is setting the variables or in the subprocess called from the
> BAT script.
> Other possibility is to set the variables in the MS Windows system
> settings but this limits you to one particular GRASS installation (others
> might be broken) and it is not as safe (concerning stability of other
> installed programs) as just setting the variables for a given process.
> In other words, the variables are inherited by subprocesses, so starting
> the BAT script just sets the variables for the BAT process but other
> processes invoked later are independent.
> https://trac.osgeo.org/grass/ticket/2424
>> Sorry for such a childish question, but being very new I hope you help me.
> Running GRASS GIS modules outside of the GRASS session is not trivial, so
> it is great that you asked for help.
> Just try to avoid cross posting next time. Speaking about that, would
> somebody (including Arthur) mind to answer the question on GIS SE?
> Vaclav
> http://lists.osgeo.org/pipermail/grass-dev/2014-October/071463.html
> https://gis.stackexchange.com/questions/120433/is-not-it-possible-to-use-grass-gis-through-command-line-access
>> Artur
>> On Fri, Oct 31, 2014 at 5:46 PM, Pietro <peter.zamb at gmail.com> wrote:
>>> Dear Artur
>>> On Thu, Oct 30, 2014 at 10:55 PM, Artur Bercik <vbubbly21 at gmail.com>
>>> wrote:
>>> > Dear GRASS-GIS users:
>>> > I wanted to use GRASS-GIS through command line access in my Windows PC.
>>> > So, I have installed GRASS GIS 7.0.0beta3 in drive C of my PC.
>>> > But, when I enter the following command in the windows command prompt:
>>> > "C:\Program Files (x86)\GRASS GIS 7.0.0beta3\bin\i.cluster.exe"
>>> > the program can't start because libint-8.dll is missing from your
>>> computer.
>>> > Try reinstalling the program...
>>> > Please help me what should I do to have the command line access to
>>> > GRASS-GIS.
>>> If you want to use GRASS without caling GRASS explicity you have to
>>> set your environment variables correctly.
>>> At work one colleague use this bat files to set the variable and use
>>> another python interpreter than the default one:
>>> rem => grass70b2 using python XY
>>> set GISBASE=C:\GRASS GIS 7.0.0beta2
>>> rem => add a environmental variable for pythonxy
>>> set PY_XY=C:\Python27
>>> rem => reading the env file for pxthonxy
>>> call "%GISBASE%\etc\env_xy.bat"
>>> cd C:\GRASS GIS 7.0.0beta2\etc\gui\scripts
>>> cd "%USERPROFILE%"
>>> "%GRASS_PYTHON%" "%GISBASE%\etc\grass70.py" %C:\Users\<<your
>>> user>>\Documents\grassdata\<<location>>\<<mapset>>
>>> if %ERRORLEVEL% GEQ 1 pause
>>> and the env_xy.bat file contains
>>> set GRASS_SH=%GISBASE%\msys\bin\sh.exe
>>> set GRASS_HTML_BROWSER=firefox
>>> rem GRASS_PYTHON=%GISBASE%\extrabin\python.exe
>>> set GRASS_PYTHON=%PY_XY%\python.exe
>>> rem PYTHONHOME=%GISBASE%\Python27
>>> set PYTHONHOME=%PY_XY%
>>> set GRASS_PROJSHARE=%GISBASE%\share\proj
>>> set PROJ_LIB=%GISBASE%\share\proj
>>> set GDAL_DATA=%GISBASE%\share\gdal
>>> set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
>>> set PATH=%GISBASE%\msys\bin;%PATH%
>>> set PATH=%GISBASE%\extrabin;%PATH%
>>> set PATH=%GISBASE%\bin;%PATH%
>>> I hope this could help to solve your problem.
>>> Pietro
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20141101/3a9500b6/attachment.html>
