[GRASS-user] r.li circular window and not integer radius
    Markus Neteler
    neteler at osgeo.org
    Mon Sep  1 14:59:27 PDT 2014
On Sat, Aug 30, 2014 at 1:42 PM, Sergio Vignali
<vignalisergio30 at gmail.com> wrote:
> Hi Markus,
> I've just checked in GRASS 7.
> If I use an integer radius or a real number the module doesn't give an error
> (see below)
> https://www.dropbox.com/s/vv5j0xkzb90j9gv/mv_setting.png?dl=0
> but it don't create the configuration file as you can see in the image below
Could you please send us the steps how you generated the circular
window, ideally in the North Carolina location?
This would accelerate to help you...
thanks
Markus
