[GRASS-user] r.li circular window and not integer radius
Sergio Vignali
vignalisergio30 at gmail.com
Tue Sep 2 11:51:27 PDT 2014
So, here my steps with GRASS 7:
I used the North Carolina mapset, I chose the raster map landuse96_28m and
set the region to this map
setup for r.li module: create new configuration file for r.li module
Select maps and define name
Name for new configuration file to create circmw
Raster map to use to select areas landuse96_28m at PERMANENT
Define sampling region(region for analysis Whole map layer
https://www.dropbox.com/s/kbbm5udk81rwwsn/r_li_shannon.png?dl=0
next>>
Insert sampling areas moving window
choose a method use keyboard to enter sampling area
https://www.dropbox.com/s/x0p2c1i5hi9021e/grass2.png?dl=0
next>>
Set moving windows
select type of shape circle
what radius size(in metres)? 50
name of the circle mask circlemw50
https://www.dropbox.com/s/jp9anfx1kur0qyx/grass3.png?dl=0
next>>
the window shows the Summary
https://www.dropbox.com/s/blinm97w90uig7f/grass4.png?dl=0
Finish>>
Do you want to create a r.li configuartion file (circmw)? Yes
The configuration file doesn't appeare on the GRASS GIS Setup for r.li
modules on the list of available sampling area configuration files
https://www.dropbox.com/s/y0mifl4dx872o7v/grass5.png?dl=0
While I'm writing my steps I see an error message on the command console
(see below)
https://www.dropbox.com/s/1b5hjmp745wh1hk/grass6.png?dl=0
anyway if I open again the setup module my configuration file is on the
list, and then
View/Edit buttom>> the window is empty
https://www.dropbox.com/s/1b5hjmp745wh1hk/grass7.png?dl=0
I hope this can help you to find the error
All the best
Sergio
2014-09-01 23:59 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Sat, Aug 30, 2014 at 1:42 PM, Sergio Vignali
> <vignalisergio30 at gmail.com> wrote:
> > Hi Markus,
> > I've just checked in GRASS 7.
> > If I use an integer radius or a real number the module doesn't give an
> error
> > (see below)
> > https://www.dropbox.com/s/vv5j0xkzb90j9gv/mv_setting.png?dl=0
> > but it don't create the configuration file as you can see in the image
> below
> Could you please send us the steps how you generated the circular
> window, ideally in the North Carolina location?
> This would accelerate to help you...
> thanks
> Markus
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140902/4f4c11b8/attachment.html>
