[GRASS-user] GRASS7: problems with WMS
Hermann Peifer
peifer at gmx.eu
Thu Sep 18 10:24:28 PDT 2014
Just to add that I continue trying to load the WMS, without success,
though. My current error message is:
ERROR 4: `/home/peifer/grassdata/laea/test/.tmp/whitefish/17189.4' does
not exist in the file system, and is not recognised as a supported
dataset name.
When looking into .tmp/whitefish, I see a series of 17189.* files, but
obviously not 17189.4:
[GRASS:test]> ls -l .tmp/whitefish/
total 1184
-rw-r--r-- 1 peifer mtr 1144239 Sep 18 19:18 17189.0.ppm
-rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.10
-rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.11
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.5
-rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.6
-rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.7
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.8
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.9
On 2014-09-18 8:41, Hermann Peifer wrote:
> Hi All,
> I am trying to load a WMS using GRASS7, which I compiled from
> svn/release branch.
> Connecting to the WMServer, selecting and adding a layer works fine, but
> I do not get any image into the map display.
> The GUI's Map Console reports:
> Unable to determine region, m.proj failed
> The console, from which I started the GUI says:
> ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12' does not exist in the
> file system, and is not recognised as a supported dataset name.
> After noting the error related to region/m.proj, I tried both: to load a
> WMS in EPSG:3035 into my LAEA location and to load another WMS in
> EPSG:4326 into my WGS84 location, whithout any luck.
> Any hints?
> Thanks in advance, Hermann
