[GRASS-user] problem to install grass70 on ubuntu 12.04
Rashad M
mohammedrashadkm at gmail.com
Fri Sep 19 01:18:36 PDT 2014
Hello Thomas,
On Fri, Sep 19, 2014 at 8:06 AM, Thomas Adams <tea3rd at gmail.com> wrote:
> Rashad,
> I've only built from source on Ubuntu -- which has been unproblematic for
> me; I'm using 14.04 currently with GRASS 7.0beta3. Here is what I do:
Is it problematic with Ubuntu 14.04 only or also on 12.04?
> (1)
> sudo apt-get install \
> build-essential \
> make flex bison gcc libgcc1 g++ cmake ccache \
> python python-dev python-qt4 python-qt4-dev \
> python-opengl \To
> python-wxversion python-wxtools python-wxgtk2.8 \
> python-dateutil libgsl0-dev python-numpy \
> wx2.8-headers wx-common libwxgtk2.8-dev libwxgtk2.8-dbg \
> libwxbase2.8-dev libwxbase2.8-dbg \
> libncurses5-dev \
> zlib1g-dev gettext \
> libtiff4-dev \
> tcl8.5-dev tk8.5-dev \
> libcairo2 libcairo2-dev \
> sqlite3 libsqlite3-dev \
> libpq-dev \
> libreadline6 libreadline6-dev libfreetype6-dev \
> txt2tags \
> libfftw3-3 libfftw3-dev \
> libqt4-core libqt4-dbg libqt4-dev libqt4-gui libqt4-sql libqt4-qt3support
> lsb-qt4 qt4-designer qt4-dev-tools qt4-doc qt4-qtconfig \
> libapt-pkg-perl resolvconf \
> libjasper-dev \
> ruby \
> subversion \
> libavcodec-dev \
> libxmu-dev \
> libavformat-dev libswscale-dev \
> checkinstall \
> libglu1-mesa-dev libxmu-dev
> It's possible other libs should be included.
> (2)
> ./configure --with-opengl-includes=/usr/include/GL --enable-64bit
> --with-cxx --with-readline --with-freetype=yes
> --with-freetype-includes=/usr/include/freetype2/ --enable-largefile=yes
> --with-opengl-libs=/usr/lib --with-geos=/usr/local/bin/geos-config
> --with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib
> --with-sqlite --with-sqlite-includes=/usr/local/include
> --with-sqlite-libs=/usr/local/lib --with-postgres
> --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib --with-python
> --with-wxwidgets=/usr/bin/wx-config --with-proj-includes=/usr/local/include
> --with-proj-libs=/usr/local/lib --with-proj-share=/usr/local/share/proj
> --with-gdal=/usr/local/bin/gdal-config
> --with-proj-includes=/usr/local/include --with-proj-libs=/usr/local/lib
> --with-netcdf=/usr/local/bin/nc-config --with-blas-libs=/usr/local/lib
> --with-blas-includes=/usr/local/include/liblas
> --with-liblas=/usr/local/bin/liblas-config
> (3) make
> (4) sudo make install
> And that's it!
> Hope this helps...
> Cheers!
> Tom
> On Thu, Sep 18, 2014 at 10:27 AM, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
>> Hmm, I don't think libgdal1h and -dev are the same thing. libgdal1h is a
>> dep of libgdal-dev and gdalbin. libgdal1h is the library and -dev is the
>> dev files that go with the library.
>> There is no libgdal1h-dev (it's libgdal-dev afaik)
>> I think the issue is that on ubuntu 12.04 the stock libgdal1-dev
>> http://packages.ubuntu.com/precise/libgdal1-dev
>> On stock systems libgdal-dev is an alias for libgdal1-dev
>> I'm not really sure what the fix here is, other than making the grass
>> ppa depend on the ubuntugis ppa, or getting the grass70 package into
>> ubuntugis and telling people to use that one. Or to copy newer gdal over
>> from ubuntugis into the grass ppa for Precise.
>> Thanks,
>> Alex
>> On 09/18/2014 05:58 AM, Rashad M wrote:
>> > Hi Markus,
>> > Pushed the proposed changes and waiting for a clean build.
>> > https://code.launchpad.net/~grass/+recipe/grass70-release
>> > On Thu, Sep 18, 2014 at 6:15 PM, Rashad M <mohammedrashadkm at gmail.com>
>> > wrote:
>> >> Yes,
>> >> I had this in control file.
>> >> libgdal-dev | libgdal1-dev,
>> http://bazaar.launchpad.net/~grass/grass/grass70_release_debian/view/head:/control
>> >> On Thu, Sep 18, 2014 at 6:01 PM, Markus Neteler <neteler at osgeo.org>
>> wrote:
>> >>> On Wed, Aug 27, 2014 at 10:23 PM, Alex Mandel
>> >>> <tech_dev at wildintellect.com> wrote:
>> >>>> libgdal1h does not exist in stock Ubuntu 12.04 but does in 14.04
>> >>>> It was a name change introduced in Debian/UbuntuGIS to deal with some
>> >>>> libtiff build issue.
>> >>>> In order for the package to work it needs to say libgdal1 ||
>> libgdal1h
>> >>>> (basically OR).
>> >>> ... was this ever implemented in the control file of the PPA?
>> >>> Still problems are reported.
>> >>> thanks,
>> >>> Markus
>> >>> _______________________________________________
>> >>> grass-user mailing list
>> >>> grass-user at lists.osgeo.org
>> >>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> >> Regards,
>> >> Rashad
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140919/f7f664fc/attachment-0001.html>
