[GRASS-user] problem to install grass70 on ubuntu 12.04
Thomas Adams
tea3rd at gmail.com
Thu Sep 18 19:36:26 PDT 2014
Rashad,
I've only built from source on Ubuntu -- which has been unproblematic for
me; I'm using 14.04 currently with GRASS 7.0beta3. Here is what I do:
(1)
sudo apt-get install \
build-essential \
make flex bison gcc libgcc1 g++ cmake ccache \
python python-dev python-qt4 python-qt4-dev \
python-opengl \
python-wxversion python-wxtools python-wxgtk2.8 \
python-dateutil libgsl0-dev python-numpy \
wx2.8-headers wx-common libwxgtk2.8-dev libwxgtk2.8-dbg \
libwxbase2.8-dev libwxbase2.8-dbg \
libncurses5-dev \
zlib1g-dev gettext \
libtiff4-dev \
tcl8.5-dev tk8.5-dev \
libcairo2 libcairo2-dev \
sqlite3 libsqlite3-dev \
libpq-dev \
libreadline6 libreadline6-dev libfreetype6-dev \
txt2tags \
libfftw3-3 libfftw3-dev \
libqt4-core libqt4-dbg libqt4-dev libqt4-gui libqt4-sql libqt4-qt3support \
lsb-qt4 qt4-designer qt4-dev-tools qt4-doc qt4-qtconfig \
libapt-pkg-perl resolvconf \
libjasper-dev \
ruby \
subversion \
libavcodec-dev \
libxmu-dev \
libavformat-dev libswscale-dev \
checkinstall \
libglu1-mesa-dev libxmu-dev
It's possible other libs should be included.
(2)
./configure --with-opengl-includes=/usr/include/GL --enable-64bit
--with-cxx --with-readline --with-freetype=yes
--with-freetype-includes=/usr/include/freetype2/ --enable-largefile=yes
--with-opengl-libs=/usr/lib --with-geos=/usr/local/bin/geos-config
--with-tcltk-includes=/usr/local/include --with-tcltk-libs=/usr/local/lib
--with-sqlite --with-sqlite-includes=/usr/local/include
--with-sqlite-libs=/usr/local/lib --with-postgres
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib --with-python
--with-wxwidgets=/usr/bin/wx-config --with-proj-includes=/usr/local/include
--with-proj-libs=/usr/local/lib --with-proj-share=/usr/local/share/proj
--with-gdal=/usr/local/bin/gdal-config
--with-proj-includes=/usr/local/include --with-proj-libs=/usr/local/lib
--with-netcdf=/usr/local/bin/nc-config --with-blas-libs=/usr/local/lib
--with-blas-includes=/usr/local/include/liblas
--with-liblas=/usr/local/bin/liblas-config
(3) make
(4) sudo make install
And that's it!
Hope this helps...
Cheers!
Tom
On Thu, Sep 18, 2014 at 10:27 AM, Alex Mandel <tech_dev at wildintellect.com>
wrote:
> Hmm, I don't think libgdal1h and -dev are the same thing. libgdal1h is a
> dep of libgdal-dev and gdalbin. libgdal1h is the library and -dev is the
> dev files that go with the library.
> There is no libgdal1h-dev (it's libgdal-dev afaik)
> I think the issue is that on ubuntu 12.04 the stock libgdal1-dev
> http://packages.ubuntu.com/precise/libgdal1-dev
> On stock systems libgdal-dev is an alias for libgdal1-dev
> I'm not really sure what the fix here is, other than making the grass
> ppa depend on the ubuntugis ppa, or getting the grass70 package into
> ubuntugis and telling people to use that one. Or to copy newer gdal over
> from ubuntugis into the grass ppa for Precise.
> Thanks,
> Alex
> On 09/18/2014 05:58 AM, Rashad M wrote:
> > Hi Markus,
> > Pushed the proposed changes and waiting for a clean build.
> > https://code.launchpad.net/~grass/+recipe/grass70-release
> > On Thu, Sep 18, 2014 at 6:15 PM, Rashad M <mohammedrashadkm at gmail.com>
> > wrote:
> >> Yes,
> >> I had this in control file.
> >> libgdal-dev | libgdal1-dev,
> http://bazaar.launchpad.net/~grass/grass/grass70_release_debian/view/head:/control
> >> On Thu, Sep 18, 2014 at 6:01 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >>> On Wed, Aug 27, 2014 at 10:23 PM, Alex Mandel
> >>> <tech_dev at wildintellect.com> wrote:
> >>>> libgdal1h does not exist in stock Ubuntu 12.04 but does in 14.04
> >>>> It was a name change introduced in Debian/UbuntuGIS to deal with some
> >>>> libtiff build issue.
> >>>> In order for the package to work it needs to say libgdal1 || libgdal1h
> >>>> (basically OR).
> >>> ... was this ever implemented in the control file of the PPA?
> >>> Still problems are reported.
> >>> thanks,
> >>> Markus
> >>> _______________________________________________
> >>> grass-user mailing list
> >>> grass-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/grass-user
> >> Regards,
> >> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140918/017487db/attachment.html>
