[GRASS-user] GRASS7: problems with WMS
Anna Petrášová
kratochanna at gmail.com
Fri Sep 19 07:02:36 PDT 2014
On Fri, Sep 19, 2014 at 7:49 AM, peifer <peifer at gmx.eu> wrote:
> Maybe this helps to locate the problem. If not: I simply have to give up
> loading a WMS with GRASS7. Hermann
> [GRASS6.4.5svn]> r.in.wms map=http://wms.cuzk.cz/wms.asp out=wms layers=kn
> srs=EPSG:3035 format=png
> Calculating tiles
> Requesting 30 tiles.
> Downloading tiles
> [GRASS7.0.0svn]> r.in.wms url=http://wms.cuzk.cz/wms.asp out=wms layers=kn
> srs=3035 format=png
> ERROR: Sorry, <input> is not a valid parameter
> ERROR: Unable to determine region, m.proj failed
I have no idea, the <input> probably refers to m.proj but m.proj has input
parameter. Could you try to run only m.proj (take some example from
manual), if it works?
Anna
> http://osgeo-org.1560.x6.nabble.com/GRASS7-problems-with-WMS-tp5162533p5162883.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140919/353c2c0a/attachment.html>
