[GRASS-user] GRASS7: problems with WMS
Anna Petrášová
kratochanna at gmail.com
Fri Sep 19 10:29:32 PDT 2014
On Fri, Sep 19, 2014 at 1:18 PM, Hermann Peifer <peifer at gmx.eu> wrote:
> On 2014-09-19 16:02, Anna Petrášová wrote:
>> I have no idea, the <input> probably refers to m.proj but m.proj has
>> input parameter. Could you try to run only m.proj (take some example
>> from manual), if it works?
> Either I am doing something terribly stupid, or m.proj is *really* broken
> in the release branch. I wonder what m.proj or cs2cs is expected to do with
> colors: [color=style] and [color=name]. Furthermore: no coordinate input
> seems to be needed, see [1]. This parameter list looks like a joke, to say
> it in a friendly way.
yes, that's pretty funny. Do you have any local changes (svn diff)? I
looked in the recent changes but there is nothing suggesting this error.
> I "fixed" all of my earlier reported issues related to m.proj and loading
> a WMS by moving from the GRASS7 release branch to svn/trunk. In trunk,
> m.proj has a reasonable parameter list [2] and loading the WMS works as
> expected.
> Hermann
> [1] Welcome to GRASS 7.0.0svn (r61824)
> [GRASS:test]> m.proj --h
> Description:
> Converts coordinates from one projection to another (cs2cs frontend).
> Keywords:
> miscellaneous, projection
> Usage:
> m.proj [-iodec] [color=style] [output=name] [separator=character]
> [color=name] [proj_in=string] [proj_out=string] [--overwrite] [--help]
> [--verbose] [--quiet]
> [2] Welcome to GRASS 7.1.svn (r62036)
> [GRASS:PERMANENT]> m.proj --help
> Description:
> Keywords:
> Usage:
> m.proj [-iodec] [coordinates=east,north] [input=name] [output=name]
> [separator=character] [proj_in=string] [proj_out=string] [--overwrite]
> [--help] [--verbose] [--quiet]
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140919/45f83d4f/attachment.html>
