[GRASS-user] removing small lines
    Levente Juhász
    jlevente89 at gmail.com
    Wed Sep 24 07:22:54 PDT 2014
Hi all,
I've seen that the remove_small method of v.generalize has been eliminated.
Reduction method does not work in the way I want since it just removes
point from lines and it seems like has no effect on a line of 2 points -
even if they're smaller than the threshold.
Can someone tell me what the workaround is for removing small lines from a
vector for example by a threshold in map units?
Cheers,
Levente
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140924/952d3e0f/attachment.html>
