[GRASS-user] Problems with r.viewshed
    Markus Neteler
    neteler at osgeo.org
    Fri Sep 26 04:07:36 PDT 2014
On Sep 26, 2014 12:37 PM, "Luis Miguel Royo Pérez" <
luis.miguel.royo at gmail.com> wrote:
> Thank you very much. That was the problem.
Please suggest how to improve the module help text or manual.
Thanks
Markus
> Sorry for any inconvenience.
> Kind regards.
> El 26/09/14 a las #4, Pedro Palheiro escribió:
>> Hello Luis,
>> Maybe it is a coordinate reference system problem? It looks like you're
using wgs84 for the input and coordinates, and requesting the calculation
in meters (obs_elev, tgt_elev and max_dist). Try to change the CRS to see
if it works.
>> r.viewshed -b input=Portada at inisig output=visPort
>> coordinates=-3.74034324324,42.5352702703
>> obs_elev=9 tgt_elev=1.75
>> max_dist=30000
>> Computing events...
>> Computing visibility...
>> r.viewshed: statusstructure.cpp:73: float
>> get_vertical_angle(Viewpoint, StatusNode, surface_type,
>> int): La declaraci?n `fabs(sn.dist2vp) > 0.001' no se
>> cumple.
>> Adios,
>> Pedro Palheiro
>> 2014-09-25 20:00 GMT+01:00 <grass-user-request at lists.osgeo.org>:
>>> Send grass-user mailing list submissions to
>>>         grass-user at lists.osgeo.org
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>         http://lists.osgeo.org/mailman/listinfo/grass-user
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>         grass-user-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of grass-user digest..."
>>> Today's Topics:
>>>    1. Re: removing small lines (Markus Neteler)
>>>    2. Problems with r.viewshed (Luis Miguel Royo P?rez)
>>>    3. Re: Problems with r.viewshed (Markus Neteler)
>>>    4. Re: Problems with r.viewshed (Luis Miguel Royo P?rez)
>>> Message: 1
>>> Date: Thu, 25 Sep 2014 10:25:25 +0200
>>> From: Markus Neteler <neteler at osgeo.org>
>>> To: Levente Juh?sz <jlevente89 at gmail.com>
>>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>>> Subject: Re: [GRASS-user] removing small lines
>>> Message-ID:
>>>         <CALFmHhsJtJ0-=
me+C_8o6+Y9CTA1P-cofD3NemuyE30uBmvF5Q at mail.gmail.com>
>>> Content-Type: text/plain; charset=UTF-8
>>> On Wed, Sep 24, 2014 at 4:22 PM, Levente Juh?sz <jlevente89 at gmail.com>
wrote:
>>> > Hi all,
>>> > I've seen that the remove_small method of v.generalize has been
eliminated.
>>> > Reduction method does not work in the way I want since it just
removes point
>>> > from lines and it seems like has no effect on a line of 2 points -
even if
>>> > they're smaller than the threshold.
>>> > Can someone tell me what the workaround is for removing small lines
from a
>>> > vector for example by a threshold in map units?
>>> You may use v.to.db and option=length (line length), then use
>>> v.extract to extract into a new map according to a threshold you need.
>>> Markus
>>> Message: 2
>>> Date: Thu, 25 Sep 2014 10:35:52 +0200
>>> From: Luis Miguel Royo P?rez <
>>> To: grass-user at lists.osgeo.org
>>> Subject: [GRASS-user] Problems with r.viewshed
>>> Message-ID: <5423D3E8.5090206 at gmail.com>
>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>> Hi everyone,
>>> when I try to run r.viewshed the output shows me this:
>>> Nodata value set to -nan
>>> rows=198, cols=217, total = 42966
>>> In-memory memory usage is 4298336 B (4 MB),             max mem
>>> allowed=524288000 B(500MB)
>>> *****  IN_MEMORY MODE  *****
>>> Start sweeping.
>>> Computing events ...
>>> Sorting events...
>>> Terminado.
>>> Determine visibility...
>>> cumple.
>>> Anyone has a clue about what it could be happening?
>>> I'm using GRASS 6.4.4 in Xubuntu 14.04.
>>> I think I must say that a few days ago I installed GRASS 7 but I removed
>>> it and reinstalled GRASS 6.4.4. Maybe is there any incompatibility?
>>> Thanks a lot!!!
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <
http://lists.osgeo.org/pipermail/grass-user/attachments/20140925/15c0ab71/attachment-0001.html
>>> Message: 3
>>> Date: Thu, 25 Sep 2014 12:46:13 +0200
>>> To: Luis Miguel Royo P?rez <luis.miguel.royo at gmail.com>
>>> Subject: Re: [GRASS-user] Problems with r.viewshed
>>> Message-ID:
>>>         <CALFmHhuPb4w+S03JwMEohU0yQaUas+0f65R=
sVaXsFFEOaTALg at mail.gmail.com>
>>> On Thu, Sep 25, 2014 at 10:35 AM, Luis Miguel Royo P?rez
>>> <luis.miguel.royo at gmail.com> wrote:
>>> > Hi everyone,
>>> (in GRASS 6 it is an Addon)
>>> > Start sweeping.
>>> > Sorting events...
>>> > Terminado.
>>> > cumple.
>>> I have backported some fixes from GRASS 7 to the addon in GRASS 6.
>>> Please reinstall the addon with g.extension and try again.
removed it
>>> No, GRASS 6 and 7 can happily live together.
>>> Please let us know if the updated Addon runs ok for you.
>>> Markus
>>> Message: 4
>>> Date: Thu, 25 Sep 2014 14:11:36 +0200
>>> From: Luis Miguel Royo P?rez <luis.miguel.royo at gmail.com>
>>> To: Markus Neteler <neteler at osgeo.org>
>>> Message-ID: <54240678.7060005 at gmail.com>
>>> I'm sorry but it didn't work.
>>> I have reinstalled the addon but it didn't work, reinstalled GRASS 6.4
>>> and neither, then installed GRASS7 again, and appears this message:
>>> coordinates=-3.74034324324,42.5352702703 obs_elev=9 tgt_elev=1.75
>>> max_dist=30000
>>> Computing events...
>>> cumple.
>>> I will try in another PC.
>>> Thank you for your time.
>>> El 25/09/14 a las #4, Markus Neteler escribi?:
>>> >> Hi everyone,
>>> >> Start sweeping.
>>> >> Sorting events...
>>> >> Terminado.
>>> >> cumple.
removed it
>>> > Markus
>>> URL: <
http://lists.osgeo.org/pipermail/grass-user/attachments/20140925/edaf5af2/attachment-0001.html
>>> End of grass-user Digest, Vol 101, Issue 39
>> Pedro Palheiro
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140926/98e572de/attachment.html>
