[GRASS-user] Problems with r.viewshed
Luis Miguel Royo Pérez luis.miguel.royo at gmail.com
Fri Sep 26 03:37:19 PDT 2014
Thank you very much. That was the problem.
Sorry for any inconvenience.
Kind regards.
El 26/09/14 a las #4, Pedro Palheiro escribió:
> Hello Luis,
> Maybe it is a coordinate reference system problem? It looks like
> you're using wgs84 for the input and coordinates, and requesting the
> calculation in meters (obs_elev, tgt_elev and max_dist). Try to change
> the CRS to see if it works.
> r.viewshed -b input=Portada en inisig output=visPort
> *coordinates=-3.74034324324,42.5352702703*
> obs_elev=9 tgt_elev=1.75
> max_dist=30000
> Computing events...
> Computing visibility...
> r.viewshed: statusstructure.cpp:73: float
> get_vertical_angle(Viewpoint, StatusNode, surface_type,
> int): La declaraci?n `*fabs(sn.dist2vp) > 0.001*' no se
> cumple.
> Adios,
> Pedro Palheiro
> 2014-09-25 20:00 GMT+01:00 <grass-user-request en lists.osgeo.org
> <mailto:grass-user-request en lists.osgeo.org>>:
>     Send grass-user mailing list submissions to
>     grass-user en lists.osgeo.org <mailto:grass-user en lists.osgeo.org>
>     To subscribe or unsubscribe via the World Wide Web, visit
>     http://lists.osgeo.org/mailman/listinfo/grass-user
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>     grass-user-owner en lists.osgeo.org
>     <mailto:grass-user-owner en lists.osgeo.org>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of grass-user digest..."
>     Today's Topics:
>        1. Re: removing small lines (Markus Neteler)
>        2. Problems with r.viewshed (Luis Miguel Royo P?rez)
>        3. Re: Problems with r.viewshed (Markus Neteler)
>        4. Re: Problems with r.viewshed (Luis Miguel Royo P?rez)
>     Message: 1
>     Date: Thu, 25 Sep 2014 10:25:25 +0200
>     From: Markus Neteler <neteler en osgeo.org <mailto:neteler en osgeo.org>>
>     To: Levente Juh?sz <jlevente89 en gmail.com
>     <mailto:jlevente89 en gmail.com>>
>     Cc: GRASS user list <grass-user en lists.osgeo.org
>     <mailto:grass-user en lists.osgeo.org>>
>     Subject: Re: [GRASS-user] removing small lines
>     Message-ID:
>     <CALFmHhsJtJ0-=me+C_8o6+Y9CTA1P-cofD3NemuyE30uBmvF5Q en mail.gmail.com <mailto:me%2BC_8o6%2BY9CTA1P-cofD3NemuyE30uBmvF5Q en mail.gmail.com>>
>     Content-Type: text/plain; charset=UTF-8
>     On Wed, Sep 24, 2014 at 4:22 PM, Levente Juh?sz
>     <jlevente89 en gmail.com <mailto:jlevente89 en gmail.com>> wrote:
>     > Hi all,
>     > I've seen that the remove_small method of v.generalize has been
>     eliminated.
>     > Reduction method does not work in the way I want since it just
>     removes point
>     > from lines and it seems like has no effect on a line of 2 points
>     - even if
>     > they're smaller than the threshold.
>     > Can someone tell me what the workaround is for removing small
>     lines from a
>     > vector for example by a threshold in map units?
>     You may use v.to.db and option=length (line length), then use
>     v.extract to extract into a new map according to a threshold you need.
>     Markus
>     Message: 2
>     Date: Thu, 25 Sep 2014 10:35:52 +0200
>     From: Luis Miguel Royo P?rez <
>     luis.miguel.royo en gmail.com <mailto:luis.miguel.royo en gmail.com>>
>     To: grass-user en lists.osgeo.org <mailto:grass-user en lists.osgeo.org>
>     Subject: [GRASS-user] Problems with r.viewshed
>     Message-ID: <5423D3E8.5090206 en gmail.com
>     <mailto:5423D3E8.5090206 en gmail.com>>
>     Content-Type: text/plain; charset="utf-8"; Format="flowed"
>     Hi everyone,
>     when I try to run r.viewshed the output shows me this:
>     Nodata value set to -nan
>     rows=198, cols=217, total = 42966
>     In-memory memory usage is 4298336 B (4 MB),  max mem
>     allowed=524288000 B(500MB)
>     *****  IN_MEMORY MODE  *****
>     Start sweeping.
>     Computing events ...
>     Sorting events...
>     Terminado.
>     Determine visibility...
>     int): La declaraci?n `fabs(sn.dist2vp) > 0.001' no se
>     cumple.
>     Anyone has a clue about what it could be happening?
>     I'm using GRASS 6.4.4 in Xubuntu 14.04.
>     I think I must say that a few days ago I installed GRASS 7 but I
>     removed
>     it and reinstalled GRASS 6.4.4. Maybe is there any incompatibility?
>     Thanks a lot!!!
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.osgeo.org/pipermail/grass-user/attachments/20140925/15c0ab71/attachment-0001.html>
>     Message: 3
>     Date: Thu, 25 Sep 2014 12:46:13 +0200
>     To: Luis Miguel Royo P?rez <luis.miguel.royo en gmail.com
>     Subject: Re: [GRASS-user] Problems with r.viewshed
>     Message-ID:
>     <CALFmHhuPb4w+S03JwMEohU0yQaUas+0f65R=sVaXsFFEOaTALg en mail.gmail.com <mailto:sVaXsFFEOaTALg en mail.gmail.com>>
>     On Thu, Sep 25, 2014 at 10:35 AM, Luis Miguel Royo P?rez
>     <luis.miguel.royo en gmail.com <mailto:luis.miguel.royo en gmail.com>>
>     wrote:
>     > Hi everyone,
>     (in GRASS 6 it is an Addon)
>     > Start sweeping.
>     > Sorting events...
>     > Terminado.
>     > cumple.
>     I have backported some fixes from GRASS 7 to the addon in GRASS 6.
>     Please reinstall the addon with g.extension and try again.
>     removed it
>     No, GRASS 6 and 7 can happily live together.
>     Please let us know if the updated Addon runs ok for you.
>     Markus
>     Message: 4
>     Date: Thu, 25 Sep 2014 14:11:36 +0200
>     From: Luis Miguel Royo P?rez <luis.miguel.royo en gmail.com
>     To: Markus Neteler <neteler en osgeo.org <mailto:neteler en osgeo.org>>
>     Message-ID: <54240678.7060005 en gmail.com
>     <mailto:54240678.7060005 en gmail.com>>
>     I'm sorry but it didn't work.
>     I have reinstalled the addon but it didn't work, reinstalled GRASS 6.4
>     and neither, then installed GRASS7 again, and appears this message:
>     coordinates=-3.74034324324,42.5352702703 obs_elev=9 tgt_elev=1.75
>     max_dist=30000
>     Computing events...
>     cumple.
>     I will try in another PC.
>     Thank you for your time.
>     El 25/09/14 a las #4, Markus Neteler escribi?:
>     wrote:
>     >> Hi everyone,
>     >> Start sweeping.
>     >> Sorting events...
>     >> Terminado.
>     >> cumple.
>     I removed it
>     > Markus
>     URL:
>     <http://lists.osgeo.org/pipermail/grass-user/attachments/20140925/edaf5af2/attachment-0001.html>
>     _______________________________________________
>     End of grass-user Digest, Vol 101, Issue 39
> Pedro Palheiro
------------ pr�xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140926/26b03f67/attachment-0001.html>
