[GRASS-user] 64 bit Python in GRASS 6.4.2
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Fri Sep 26 08:22:34 PDT 2014
Hi Andy,
You can try this:
http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe
Cheers,
Saber
[mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Orr, Andrew B.
Sent: 26 September 2014 15:46
To: 'grass-user at lists.osgeo.org'
Subject: [GRASS-user] 64 bit Python in GRASS 6.4.2
Hello all,
I've been working on a r.cost and r.drain python script that is using very
large rasters. I've been running into some memory issues with this script
due to the size of the rasters. I read about setting the amount of memory
that the map can be stored in with the "percent_memory=xx" argument for
r.cost, however the performance of running the script is becoming a problem
(it takes too long to run for our goal).
I then started watching the Task Manager and noticed it was peaked out at
less ~4 gigs of ram and I realized it's only a 32 bit version of Python
installed with GRASS.
My question is: is there a compatible 64 bit version of Python for GRASS
6.4.x, and if so, how does one install it?
Thanks for your help!
-Andy
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140926/9ae1c3e3/attachment-0001.html>
