[GRASS-user] get vector table with unique feature id
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Apr 3 07:51:35 PDT 2015
On Fri, Apr 3, 2015 at 3:22 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> On Fri, Apr 3, 2015 at 3:11 PM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> On 03/04/15 14:42, Paulo van Breugel wrote:
>>> I have a shapefile with overlapping polygons. After importing I thus
>>> end up with a vector layer with for each unique polygon (feature) one
>>> or more category values (i.e., one to many relationship).
>>> Now I want to create a second attribute table linked to layer 2 with
>>> a cat column with for each polygon (for each internal feature id) an
>>> unique category.
>>> Next, I want to use this to count the number of categories linked to
>>> each unique feature id.
>> If you have overlapping polygons, after running v.in.ogr your map
>> already has layer 2 categories which represent for each feature where
>> there is overlap the number of overlapping polygons in that space. IIUC,
>> this is what you are looking for, or ?
> Yes, sorry, I was just about to write that this is indeed the case; you
> were just ahead of me. In my initial attempt something went wrong, I should
> have checked better, but was focused on getting a column with the unique
> values per polygon (which as you write below does not seem to work?).
>>> I know this has been asked and answered before, but the solutions
>>> (copied below) do not work for me.
>>> This worked, I think, in GRASS 6, but it doesn't in G7 because a new
>>> vector map needs to be defined
>>>> /v.category op=add layer=2 type=centroid/ /v.to.db type=centroid
>>>> option=cat/
>> And what is the problem with defining a new vector map. This new vector
>> map will contain all existing layers plus the new layer. But in this
>> case it should be:
>> v.category map op=add layer=3 type=centroid out=map2
>> You can then create a table for layer 3 with v.db.addtable:
>> v.db.addtable map2 layer=3 columns="cat2 integer"
>> and should be able to load the cat values of layer 2 into the table of
>> layer 3 with v.to.db,
> I knew (ok, I hoped) this should be simple. Thanks
>> but this does not seem to work at the moment:
>> v.to.db map22 layer=3 query_layer=2 op=cat columns=cat2
>> (there seems to be confusion between map layers, but I don't have time to
>> check. Definitely worth a bug report.)
> I'll create one
Created a ticket: Ticket #2641
>> The below does not create an attribute table with unique attributes
>>> for each unique feature. /> v.in.ogr dsn=test_polygones.shp
>>> out=polygons
>>> v.db.addtable polygons layer=2
>> > v.category polygons option=add
>>> layer=2 type=centroid out=polygons_tmp
>>> v.to.db polygons_tmp
>>>> type=centroid option=cat layer=2 col=cat/
>> For those features where there is overlap, this will not create new
>> categories, but upload to the table the existing category which is the
>> number of overlapping features.
> OK, I was confused here, thanks for the explanation
>> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150403/282a8f93/attachment-0001.html>
