[GRASS-user] v.isochrones : error message
lcelati at cci-paris-idf.fr
Sat Apr 4 15:03:35 PDT 2015
Hello,
I'm working with grass 7 on windows 7 8 go RAM 64 bits.
When i execute the v.isochrones process, there is an error message and the
process does not work.
Below, i paste the interface of the v.isochrones output command:
/(Sat Apr 04 23:55:36 2015)
v.isochrones --overwrite map=roads_merge_idf_picardie_L93 at data_set layer=1
speed_column=maxspeed start_points=MANUTAN_starting_points_L93 at data_set
isochrones=vector_map timemap=raster_map time_steps=15,30,45
Pass 1 of 163659:
Reading features...
Writing raster map...
File "C:\Users\ramaioli\AppData\Roaming\GRASS7\addons/scri
pts/v.isochrones.py", line 211, in <module>
main()
pts/v.isochrones.py", line 154, in main
type='line')
File "C:\Program Files (x86)\GRASS GIS
7.0.0\etc\python\grass\script\core.py", line 375, in
run_command
return handle_errors(returncode, returncode, args,
kwargs)
7.0.0\etc\python\grass\script\core.py", line 310, in
handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['v.to.rast', 'input=roads_merge_idf_picardie_L93 at data_set',
'use=attr', 'out=cost_map_tmp_5488', 'type=line',
'attrcolumn=tmp5488'] ended with error
Process ended with non-zero return code -1073741571. See
errors in the (error) output.
(Sat Apr 04 23:57:02 2015) La commande s'est terminée (1 min 25 sec)
Could you help me? Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-isochrones-error-message-tp5199989.html
Sent from the Grass - Users mailing list archive at Nabble.com.
