[GRASS-user] TIN to raster conversion module - <v.tin.to.rast>
Alexander Muriy
amuriy at gmail.com
Sun Apr 5 12:30:15 PDT 2015
Thanks for your answer, Anna :) I'm not sure about <g.region> stuff, but
I'm ready to upload scripts to grass-addons SVN.
2015-04-05 21:33 GMT+03:00 Anna Petrášová <kratochanna at gmail.com>:
> Hello,
> On Sun, Apr 5, 2015 at 5:02 AM, Alexander Muriy <amuriy at gmail.com> wrote:
>> Hello all!
>> I have corrected and adapted to recent GRASS versions (6.4.* and 7.0) the
>> script of Antonio Alliegro "tin.to.raster".
>> These are 2 separate scripts for 6.4.* and 7.0:
>> https://github.com/amuriy/GRASS-scripts/blob/master/Python/v.tin.to.rast_G64.py
>> https://github.com/amuriy/GRASS-scripts/blob/master/Python/v.tin.to.rast_G70.py
>> Could you test them, please? Maybe some errors or enhancements? Thanks in
>> advance!
> thank you for your contribution. I tried the G7 version and works great,
> just fix please the clean up, you use old g.remove interface, it should be:
> grass.run_command('g.remove', type='raster', name=tmp).
> Also I would remove stderr = nuldev from all run_commands, not sure why
> they are there.
> Have you considered uploading the scripts in the official GRASS addons
> repository? It would be easier for people to install it then. And it could
> be maintained by other developers too.
> http://trac.osgeo.org/grass/wiki/HowToContribute#WriteaccesstotheGRASS-Addons-SVNrepository
> Cheers,
> Anna
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150405/7141cdb1/attachment.html>
