[GRASS-user] Line_Height to db attribute
Nick Cahill
ndcahill at wisc.edu
Wed Apr 8 15:56:39 PDT 2015
I have a series of vector contour maps imported from CAD files. The CAD lines were digitized in 3d so the lines were set at the proper height, and I imported them with v.in.dxf. The z values now come in as Line_height values:
east, north: 586205.150707, 4261840.15315
map28 at PERMANENT:
Type: Line
Length: 1005.435416
Line_height: 160.0
Layer: 1
Category: 120
Driver: sqlite
Database: /Users/nick/Documents/Grass/sardis/PERMANENT/dbf/sardisutm.rsd
Table: map28_con10
Key_column: cat
Attributes:
cat: 120
layer: CON10
entity: LWPOLYLINE
handle: 3E1
I’m sure there’s an easy way to get those Line_Height values into proper z coordinates, but I cannot figure out how to do it. Any help would be greatly appreciated!
Many thanks,
Nick Cahill
