[GRASS-user] default database grass 7.1?
Margherita Di Leo
diregola at gmail.com
Thu Apr 23 00:27:26 PDT 2015
I run into this issue today:
r.to.vect input=tty output=tty type=area --o
Extracting areas...
Writing areas...
dbmi: Protocol error
ERROR: Cannot insert new row: insert into tty values (3968805, 12, '')
Running db.connect -p I found out that my database was dbf. I'm
running GRASS 7.1.svn (r65027). Naive question: default database is not
sqlite?
db.connect --help
Description:
Prints/sets general DB connection for current mapset.
Keywords:
database, attribute table, connection settings
Usage:
db.connect [-pgcd] [driver=name] [database=name] [schema=name]
[group=string] [--help] [--verbose] [--quiet] [--ui]
Flags:
-p Print current connection parameters and exit
Substitute variables in database settings
-g Print current connection parameters using shell style and exit
-c Check connection parameters, set if uninitialized, and exit
-d Set from default settings and exit
Overwrite current settings if already initialized
--h Print usage summary
--v Verbose module output
--q Quiet module output
--ui Force launching GUI dialog
Parameters:
driver Name of database driver
options: ogr,sqlite,dbf
default: sqlite
database Name of database
*default: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/*
schema Database schema
Do not use this option if schemas are not supported by
driver/database server
group Default group of database users to which select privilege is
granted
I'm puzzled.
madi before massive morning coffee.
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150423/f5dfa5f2/attachment.html>
