[GRASS-user] default database grass 7.1?
Markus Neteler neteler at osgeo.org
Thu Apr 23 00:53:06 PDT 2015
On Thu, Apr 23, 2015 at 9:27 AM, Margherita Di Leo <diregola at gmail.com> wrote:
> Hi,
> I run into this issue today:
> r.to.vect input=tty output=tty type=area --o
> Extracting areas...
> Writing areas...
> dbmi: Protocol error
> ERROR: Cannot insert new row: insert into tty values (3968805, 12, '')
> Running db.connect -p I found out that my database was dbf. I'm running
> GRASS 7.1.svn (r65027). Naive question: default database is not sqlite?
AFAIK, since May 2009 SQLite is the default. Did you recycle an older
location/mapset?
Markus
