[GRASS-user] Label vector map
Anna Petrášová kratochanna at gmail.com
Wed Aug 26 06:25:15 PDT 2015
On Wed, Aug 26, 2015 at 7:25 AM, henk witte <henk.witte at groenholland.nl>
wrote:
> Well, this is embarrassing – I cannot open my own pack!
Not your fault, it is fixed now.
> I created a new workspace with a default Cartesian projection but if I try
> to unpack I get
> IOError: [Errno 2] No such file or directory: 'C:\\Users\\he
> nkwitte.GROENHOLLAND\\Documents\\grassdata/test/henkwitte/.t
> mp/unknown/8544.0\\PROJ_INFO'
> I have tries also with using the current-location-projection option, but
> same error.
> With regard to the labelling, you are telling me you can label KOPER_NAAM
> and STRAATNAAM but these should not be attributes in the vector file
> AllleKavels. The field I try to use in the label is kavel_nr. I have
> repacked the vector file, if there are other attributes in this file than
> that is strange as well (however, I did join this vector file to a new
> database with different attributes – can something go wrong there?)
So I tried the exact command you used on Windows 8, GRASS GIS 7.0.0 and
7.0.1 and it works for me. The column names are:
db.describe -c table=KavelsGemeente
ncols: 19
nrows: 136
Column 1: cat:INTEGER:20
Column 2: OBJECTID:INTEGER:20
Column 3: KAVEL_NR:CHARACTER:50
Column 4: KOPER:CHARACTER:50
Column 5: PRIJS:CHARACTER:50
Column 6: VERKOOPTEK:CHARACTER:50
Column 7: DATUM:CHARACTER:50
Column 8: HUISNUMMER:CHARACTER:254
Column 9: KOPER_NAAM:CHARACTER:50
Column 10: STRAATNAAM:CHARACTER:50
Column 11: HYPERLINK:CHARACTER:100
Column 12: BOUWJAAR:CHARACTER:4
Column 13: ERFPACHTCA:DOUBLE PRECISION:20
Column 14: PERCEELPRI:DOUBLE PRECISION:20
Column 15: ERFPACHT_1:DOUBLE PRECISION:20
Column 16: PERCEELP_1:DOUBLE PRECISION:20
Column 17: OPPERVLAKT:DOUBLE PRECISION:20
Column 18: SHAPE_AREA:DOUBLE PRECISION:20
Column 19: SHAPE_LEN:DOUBLE PRECISION:20
So I am not sure what to do about it.
Anna
Thanks
> Henkn
> *From:* Micha Silver [mailto:micha at arava.co.il]
> *Sent:* 26 August 2015 12:30
> *To:* henk witte <henk.witte at groenholland.nl>
> *Cc:* grass-user at lists.osgeo.org
> *Subject:* Re: [GRASS-user] Label vector map
> I tried your vector pack file, and I have no problems displaying both
> KOPER_NAAM and  STRAATNAAM columns as labels on the map display. (On linux,
> not Windows)
> HTH,
> Micha
> On 25/08/2015 20:49, henk witte wrote:
> Sorry, I am new to GRASS and still have to learn a lot of the basics.
> Still – great product that allows me to create maps that I need fairly
> easily!
> I have now run v.pack to create the vector file.
> I am not entirely familiar with the projections, as I imported most data
> from esri shapefiles and use X- and Y-coordinates in the Dutch RGD system
> (basically meters easting and northing) I did not worry to much about the
> projection (the region is small). If I run g.proj –p I get:
> (Tue Aug 25 19:41:59
> 2015)
> g.proj
> -p
> XY location (unprojected)
> (Tue Aug 25 19:41:59 2015) Command finished (0 sec)
> Basically it tells me I am using an unprojected mapset.
> Hope this helps!
> Henk
> *From:* Anna Petrášová [mailto:kratochanna at gmail.com
> <kratochanna at gmail.com>]
> *Sent:* 25 August 2015 18:37
> *To:* henk witte <henk.witte at groenholland.nl> <henk.witte at groenholland.nl>
> On Tue, Aug 25, 2015 at 2:51 AM, henk witte <henk.witte at groenholland.nl>
> wrote:
> Dear Anna,
> Thanks for your suggestions, I have tried the North Carolina dataset
> (using the NAME attribute of the counties as label) and this indeed works
> fine. I have also tried my original file, and there I still have problems.
> The vector (polygon) files I wanted to label have been created from two
> separate source files (imported from esri shape files) that I have merged.
> During the merge I noted a number of problems with the polygons, although
> it now displays OK. After this I joined the vector file with a new
> attribute table. I can use that to color the polygons (create thematic
> maps) but I cannot label the polygons even if I use the grass-generated
> “cat”column.
> I have tried not specifying a font at all (default) and then did specify a
> font to see if that would help. Unfortunately not.
> I have added the vector file (directory) as a zip file to this email.
> Could you please use v.pack to send us the vector, you can't just take the
> directory with the vector, the attribute data are stored separately and
> v.pack takes care of that. Also which projection are you working in? Could
> you send the EPSG? Thank you
> Anna
> Thanks for any further assistance!
> Henk
> *From:* Anna Petrášová [mailto:kratochanna at gmail.com]
> *Sent:* 21 August 2015 17:58
> On Fri, Aug 21, 2015 at 5:24 AM, henk witte <henk.witte at groenholland.nl>
> wrote:
> Dear grass-users,
> I am trying to put labels in a polygon layer, but the rendering fails. The
> details are:
> *Problem signature:*
>   Problem Event Name:                        APPCRASH
>   Application Name:                             d.vect.EXE
>   Application Version:                           7.0.0.0
>   Application Timestamp:                     55ae1991
>   Fault Module Name:                          libgrass_driver.7.0.1svn.dll
>   Fault Module Version:                        0.0.0.0
>   Fault Module Timestamp:                  55ae17e1
>   Exception Code:                                  c0000005
>   Exception Offset:                                00002aa5
>   OS Version:
> 6.1.7601.2.1.0.256.48
>   Locale ID:                                             2057
>   Additional Information 1:                  0a9e
>   Additional Information 2:
> 0a9e372d3b4ad19135b953a78882e789
>   Additional Information 3:                  0a9e
>   Additional Information 4:  0a9e372d3b4ad19135b953a78882e789
> The command I use (through the GUI) is:
> d.vect --quiet map=AlleKavels at GoesShape attribute_column=Kavel_nr width=1
> font=romans label_color=black
> Any suggestions?
> Perhaps if you could replicate the problem on North Carolina sample
> dataset or provide your vector file, it would help identify the problem.
> Does it happen with other vectors or attribute columns? Have you tried
> different font or not specify it at all?
> Anna
> Henk Witte
> Groenholland Geo-energysystems
> Valschermkade 26
> 1059CD Amsterdam
> T: +31 (0)20 6159050
> M: +31 (0)628176535
> E: henk.witte at groenholland.nl
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150826/a2cd84d8/attachment-0001.html>
