[GRASS-user] Label vector map
henk witte henk.witte at groenholland.nl
Wed Aug 26 06:51:18 PDT 2015
Hi Anna/Micha,
Guess the wrong vector was exported, should be the map  Allekavels and attribute Kavel_nr.
I repacked the vector file. I tried to reopen it using Micha;s method, I can unzip the pack file (gz) without problems - but cannot add the maplayer to a new system. Is there a new build available with the fix? I checked http://wingrass.fsv.cvut.cz/grass71/ but the last build is 25/8/2015.
I'll check again tomorrow.
Henk
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: 26 August 2015 15:25
To: henk witte <henk.witte at groenholland.nl>
Cc: Micha Silver <micha at arava.co.il>; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Label vector map
On Wed, Aug 26, 2015 at 7:25 AM, henk witte <henk.witte at groenholland.nl<mailto:henk.witte at groenholland.nl>> wrote:
Well, this is embarrassing - I cannot open my own pack!
Not your fault, it is fixed now.
I created a new workspace with a default Cartesian projection but if I try to unpack I get
IOError: [Errno 2] No such file or directory: 'C:\\Users\\he
nkwitte.GROENHOLLAND\\Documents\\grassdata/test/henkwitte/.t
mp/unknown/8544.0\\PROJ_INFO'
I have tries also with using the current-location-projection option, but same error.
With regard to the labelling, you are telling me you can label KOPER_NAAM and STRAATNAAM but these should not be attributes in the vector file AllleKavels. The field I try to use in the label is kavel_nr. I have repacked the vector file, if there are other attributes in this file than that is strange as well (however, I did join this vector file to a new database with different attributes - can something go wrong there?)
So I tried the exact command you used on Windows 8, GRASS GIS 7.0.0 and 7.0.1 and it works for me. The column names are:
db.describe -c table=KavelsGemeente
ncols: 19
nrows: 136
Column 1: cat:INTEGER:20
Column 2: OBJECTID:INTEGER:20
Column 3: KAVEL_NR:CHARACTER:50
Column 4: KOPER:CHARACTER:50
Column 5: PRIJS:CHARACTER:50
Column 6: VERKOOPTEK:CHARACTER:50
Column 7: DATUM:CHARACTER:50
Column 8: HUISNUMMER:CHARACTER:254
Column 9: KOPER_NAAM:CHARACTER:50
Column 10: STRAATNAAM:CHARACTER:50
Column 11: HYPERLINK:CHARACTER:100
Column 12: BOUWJAAR:CHARACTER:4
Column 13: ERFPACHTCA:DOUBLE PRECISION:20
Column 14: PERCEELPRI:DOUBLE PRECISION:20
Column 15: ERFPACHT_1:DOUBLE PRECISION:20
Column 16: PERCEELP_1:DOUBLE PRECISION:20
Column 17: OPPERVLAKT:DOUBLE PRECISION:20
Column 18: SHAPE_AREA:DOUBLE PRECISION:20
Column 19: SHAPE_LEN:DOUBLE PRECISION:20
So I am not sure what to do about it.
Anna
Thanks
Henkn
From: Micha Silver [mailto:micha at arava.co.il<mailto:micha at arava.co.il>]
Sent: 26 August 2015 12:30
To: henk witte <henk.witte at groenholland.nl<mailto:henk.witte at groenholland.nl>>
Cc: grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
I tried your vector pack file, and I have no problems displaying both KOPER_NAAM and  STRAATNAAM columns as labels on the map display. (On linux, not Windows)
HTH,
Micha
On 25/08/2015 20:49, henk witte wrote:
Sorry, I am new to GRASS and still have to learn a lot of the basics. Still - great product that allows me to create maps that I need fairly easily!
I have now run v.pack to create the vector file.
I am not entirely familiar with the projections, as I imported most data from esri shapefiles and use X- and Y-coordinates in the Dutch RGD system (basically meters easting and northing) I did not worry to much about the projection (the region is small). If I run g.proj -p I get:
(Tue Aug 25 19:41:59 2015)
g.proj -p
XY location (unprojected)
(Tue Aug 25 19:41:59 2015) Command finished (0 sec)
Basically it tells me I am using an unprojected mapset.
Hope this helps!
Henk
Sent: 25 August 2015 18:37
To: henk witte <henk.witte at groenholland.nl><mailto:henk.witte at groenholland.nl>
On Tue, Aug 25, 2015 at 2:51 AM, henk witte <henk.witte at groenholland.nl<mailto:henk.witte at groenholland.nl>> wrote:
Dear Anna,
Thanks for your suggestions, I have tried the North Carolina dataset (using the NAME attribute of the counties as label) and this indeed works fine. I have also tried my original file, and there I still have problems.
The vector (polygon) files I wanted to label have been created from two separate source files (imported from esri shape files) that I have merged. During the merge I noted a number of problems with the polygons, although it now displays OK. After this I joined the vector file with a new attribute table. I can use that to color the polygons (create thematic maps) but I cannot label the polygons even if I use the grass-generated "cat"column.
I have tried not specifying a font at all (default) and then did specify a font to see if that would help. Unfortunately not.
I have added the vector file (directory) as a zip file to this email.
Could you please use v.pack to send us the vector, you can't just take the directory with the vector, the attribute data are stored separately and v.pack takes care of that. Also which projection are you working in? Could you send the EPSG? Thank you
Anna
Thanks for any further assistance!
Henk
From: Anna Petrášová [mailto:kratochanna at gmail.com<mailto:kratochanna at gmail.com>]
Sent: 21 August 2015 17:58
On Fri, Aug 21, 2015 at 5:24 AM, henk witte <henk.witte at groenholland.nl<mailto:henk.witte at groenholland.nl>> wrote:
Dear grass-users,
I am trying to put labels in a polygon layer, but the rendering fails. The details are:
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             d.vect.EXE
  Application Version:                           7.0.0.0
  Application Timestamp:                     55ae1991
  Fault Module Name:                          libgrass_driver.7.0.1svn.dll
  Fault Module Version:                        0.0.0.0
  Fault Module Timestamp:                  55ae17e1
  Exception Code:                                  c0000005
  Exception Offset:                                00002aa5
  OS Version:                                          6.1.7601.2.1.0.256.48
  Locale ID:                                             2057
  Additional Information 1:                  0a9e
  Additional Information 2:                  0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:                  0a9e
  Additional Information 4:  0a9e372d3b4ad19135b953a78882e789
The command I use (through the GUI) is:
d.vect --quiet map=AlleKavels at GoesShape attribute_column=Kavel_nr width=1 font=romans label_color=black
Any suggestions?
Perhaps if you could replicate the problem on North Carolina sample dataset or provide your vector file, it would help identify the problem. Does it happen with other vectors or attribute columns? Have you tried different font or not specify it at all?
Anna
Henk Witte
Groenholland Geo-energysystems
Valschermkade 26
1059CD Amsterdam
T: +31 (0)20 6159050<tel:%2B31%20%280%2920%206159050>
M: +31 (0)628176535<tel:%2B31%20%280%29628176535>
E: henk.witte at groenholland.nl<mailto:henk.witte at groenholland.nl>
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
This mail was received via Mail-SeCure System.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150826/8a792167/attachment-0001.html>
Type: application/octet-stream
Desc: Allkavels.pack
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150826/8a792167/attachment-0001.obj>
