[GRASS-user] error while displaying netCDF file
    Veronica Andreo
    veroandreo at gmail.com
    Wed Dec 16 13:01:11 PST 2015
Hi list,
I'm trying to import a netCDF file I downloaded from here:
http://oceandata.sci.gsfc.nasa.gov/MODISA/Mapped/8Day/4km/chl/
I've tried two different ways of importing:
r.in.gdal input=NETCDF:"A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc":chl_ocx
output=test_chlor -o
and
gdal_translate -a_srs EPSG:4326 -a_ullr -180 90 180 -90 NETCDF:"
A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc":chl_ocx test_chlor_b.tif
r.in.gdal input=test_chlor_b.tif output=test_chlor_b
In both cases I get this error when trying to display the map (both with
d.mon - d.rast and in the GUI):
*GRASS_INFO_ERROR(18597,1): Syntax error in cell header*
*GRASS_INFO_END(18597,1)*
though, r.info test_chlor_b, seems fine
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    FCELL
 |   Rows:         4320
 |   Columns:      8640
 |   Total Cells:  37324800
 |        Projection: Latitude-Longitude
 |            N:        90N    S:        90S   Res: 0:02:30
 |            E:       180E    W:       180W   Res: 0:02:30
 |   Range of data:    min = 0.001  max = 99.96646
While transforming with gdal_translate and also when unsing r.in.gdal with
the original netCDF file, I noted this:
*Warning 1: dimension #1 (lon) is not a Longitude/X dimension.*
*Warning 1: dimension #0 (lat) is not a Latitude/Y dimension.*
Input file size is 8640, 4320
0...10...20...30...40...50...60...70...80...90...100 - done.
I guess it is maybe related to the error? What does it mean? Can someone
help me, please? QGIS displays it fine...
I'm using grass71 r67160, under fedora 22. GDAL 1.11.3
Thanks a lot! And sorry for my ignorance :/
Vero
ps: Here, the output of gdalinfo from original netCDF and the one converted
with gdal_translate: http://pastebin.com/4c7Hk7cW
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151216/8222012d/attachment.html>
