[GRASS-user] error while displaying netCDF file
Veronica Andreo
veroandreo at gmail.com
Wed Dec 16 13:43:51 PST 2015
Sorry for the noise :)
I solved it.
Just forgot "-l" in r.in.gdal and then set the bounds of the map properly
with r.region.
Cheers,
Vero
2015-12-16 18:01 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi list,
> I'm trying to import a netCDF file I downloaded from here:
> http://oceandata.sci.gsfc.nasa.gov/MODISA/Mapped/8Day/4km/chl/
> I've tried two different ways of importing:
> r.in.gdal input=NETCDF:"A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc":chl_ocx
> output=test_chlor -o
> and
> gdal_translate -a_srs EPSG:4326 -a_ullr -180 90 180 -90 NETCDF:"
> A20030012003008.L3m_8D_CHL_chl_ocx_4km.nc":chl_ocx test_chlor_b.tif
> r.in.gdal input=test_chlor_b.tif output=test_chlor_b
> In both cases I get this error when trying to display the map (both with
> d.mon - d.rast and in the GUI):
> *GRASS_INFO_ERROR(18597,1): Syntax error in cell header*
> *GRASS_INFO_END(18597,1)*
> though, r.info test_chlor_b, seems fine
> | Type of Map: raster Number of Categories: 0
> | Data Type: FCELL
> | Rows: 4320
> | Columns: 8640
> | Total Cells: 37324800
> | Projection: Latitude-Longitude
> | N: 90N S: 90S Res: 0:02:30
> | E: 180E W: 180W Res: 0:02:30
> | Range of data: min = 0.001 max = 99.96646
> While transforming with gdal_translate and also when unsing r.in.gdal with
> the original netCDF file, I noted this:
> *Warning 1: dimension #1 (lon) is not a Longitude/X dimension.*
> *Warning 1: dimension #0 (lat) is not a Latitude/Y dimension.*
> Input file size is 8640, 4320
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> I guess it is maybe related to the error? What does it mean? Can someone
> help me, please? QGIS displays it fine...
> I'm using grass71 r67160, under fedora 22. GDAL 1.11.3
> Thanks a lot! And sorry for my ignorance :/
> Vero
> ps: Here, the output of gdalinfo from original netCDF and the one
> converted with gdal_translate: http://pastebin.com/4c7Hk7cW
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151216/75e04eda/attachment.html>
