[GRASS-user] r.stream extension installation error
Carlos Grohmann
carlos.grohmann at gmail.com
Tue Dec 22 16:30:32 PST 2015
Hi all,
after a while I decided to upgrade one of my machines to OSX El Capitan and
test Michael Barton's binaries.
All works fine, including 3D viewing (which is giving me headaches on
Yosemite). I do get some verbosity on the terminal while moving the mouse
around over the wx interface:
2015-12-22 22:25:41.799 Python[746:7507] outHitPart = -1
2015-12-22 22:25:41.799 Python[746:7507] inOptions: {
"is.flipped" = 1;
kCUIPartMaskKey = 768;
kCUIThumbProportionKey = "0.25";
state = normal;
value = 0;
widget = scrollbar;
"is.flipped" = 1;
state = normal;
value = 0;
widget = scrollbar;
2015-12-22 22:25:41.800 Python[746:7507] outHitPart = 6
But the real motive of this message is that two of the r.stream.* modules
are not installing:
g.extension extension=r.stream.variables svnurl=
http://svn.osgeo.org/grass/grass-addons/grass7
Fetching <r.stream.variables> from GRASS-Addons SVN repository (be
patient)...
Compiling...
make: *** No rule to make target `/var/folders/wq/mdsw_st97b
l_8828pmm49fdr0000gn/T/tmpShWWd0/r.stream.variables/scripts/
r.stream.variables', needed by `script'. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
(Tue Dec 22 22:18:33 2015) Command finished (4 sec)
(Tue Dec 22 22:18:39 2015)
g.extension extension=r.stream.watersheds svnurl=
Fetching <r.stream.watersheds> from GRASS-Addons SVN repository (be
patient)...
Compiling...
l_8828pmm49fdr0000gn/T/tmpHnHf5r/r.stream.watersheds/scripts
/r.stream.watersheds', needed by `script'. Stop.
(Tue Dec 22 22:18:44 2015) Command finished (4 sec)
maybe some housekeeping is needed to make sure all works fine?
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151222/bb324fce/attachment.html>
