[GRASS-user] GRASS pygrass - composite
Pierric de Laborie pierric.delaborie at gmail.com
Wed Feb 11 01:02:45 PST 2015
Hello,
I am using Grass 7.0 through Python and Pygrass (from outside Grass without
starting it) on Linux (Debian GNU/Linux 7.6 (wheezy)) .
I don't understand why Grass seems to get stuck on the following Python
command :
*r.composite(red="B4",green="B3",blue="B2",output="mycomposite",quiet=QUIET,overwrite=OVR)*
Here is the information message coming from Grass :
*Creating color table for output raster map...*
*0..6..12..18..25..31..37..43..50..56..62..68..75..81..87..93..100*
*Writing raster map <mycomposite>...*
*0..*
I checked the process and memory usage and apparently Grass uses about 100%
of the CPU time and only uses half of the memory available.
Would there be a way to have more debug / warning information to understand
what Grass is doing?
Thanks
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150211/df494298/attachment.html>
