[GRASS-user] difference between the sum and num options in v.rast.stats
Roy
royroge at outlook.com
Thu Feb 12 03:01:36 PST 2015
Hi, Margherita
> what is the difference between the sum and num options in
> v.rast.stats?
> comparing the results of the two columns they appear to be the
> same, but
> I'm sure I'm missing something.
> Thanks for any pointers
sum is the sum of values and "num" (n) is the number of cells,
if you have all cells = 1, in this case sum = num
if this is not the case (all cells = 1) maybe something is wrong ...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150212/08f157d4/attachment.html>
