[GRASS-user] Is the location's VAR file required?
Markus Metz
markus.metz.giswork at gmail.com
Wed Feb 18 11:55:46 PST 2015
Hi Giovanni,
On Wed, Feb 18, 2015 at 7:26 PM, G. Allegri <giohappy at gmail.com> wrote:
> Hi Markus,
> I wrote the details in another recent email and I forgot to write the here,
> sorry.
> GRASS 7.0.0 RC1 on Ubuntu 14.04.
are you on 32 bit or 64 bit?
Please try trunk or current svn of 7.0, a number of bugs have been
fixed in the meantime.
Markus M
> I'm creating a temporary database with an empty start location, with no CRS
> defined (proj code 0, i.e. XY).
> My location contains only the the WIND and DEFAULT_WIND files with the
> following content:
> proj: 0
> zone: 0
> north: 1
> south: 0
> east: 1
> west: 0
> cols: 1
> rows: 1
> e-w resol: 1
> n-s resol: 1
> top: 1
> bottom: 0
> cols3: 1
> rows3: 1
> depths: 1
> e-w resol3: 1
> n-s resol3: 1
> t-b resol: 1
> The env variables I'm using are:
> export PYTHONPATH='/usr/lib/grass70/etc/python'
> export GISRC='/tmp/tmp9YVf_N/gisrc'
> export GRASS_VERSION='7.0.0'
> export
> PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
> export GIS_LOCK=$$
> export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
> export GISBASE='/usr/lib/grass70'
> Whatevere shapefile I try to import I obtain a segfault.
> This is the test command:
> :/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
> location=workLocation -ie
> If I add the VAR file with:
> DB_DRIVER: sqlite
> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> eveythign works fine.
> giovanni
> 2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com> wrote:
>> > I'm getting segmentation faults in case I run a command on a location
>> > missing the VAR file.
>> On which OS, which GRASS version?
>> > I thought it was optional, as it's said here:
>> > http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
>> Please post a reproducible example, thanks.
>> Markus
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
