[GRASS-user] Is the location's VAR file required?
G. Allegri giohappy at gmail.com
Wed Feb 18 13:33:30 PST 2015
Here I am,
it seems that trunk is working. I didn't obtain segfault anymore.
But now the import (to a new location) doesn't works for me. I did the same
as in the previous release versione, even changing "dns" to "input".
I will investigate more.
2015-02-18 22:14 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> On Wed, Feb 18, 2015 at 4:01 PM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> On Wed, Feb 18, 2015 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > I think we should really implement #2579 [1] in one way or the other.
>> This
>> > would make custom setups [2] not necessary for most cases. What do you
>> > think? What should be the command line parameters?
>> Importing a shapefile to a new location without a VAR file works for
>> me, and I think we should find out why it does not work for Giovanni.
>> His approach should (must) work as it is.
> Could this be related?
> http://lists.osgeo.org/pipermail/grass-dev/2014-September/070639.html
> Anna
>> Markus M
>> > Vaclav
>> > [1] http://trac.osgeo.org/grass/ticket/2579
>> > [2]
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
>> > On Wed, Feb 18, 2015 at 1:26 PM, G. Allegri <giohappy at gmail.com> wrote:
>> >> Hi Markus,
>> >> I wrote the details in another recent email and I forgot to write the
>> >> here, sorry.
>> >> GRASS 7.0.0 RC1 on Ubuntu 14.04.
>> >> I'm creating a temporary database with an empty start location, with no
>> >> CRS defined (proj code 0, i.e. XY).
>> >> My location contains only the the WIND and DEFAULT_WIND files with the
>> >> following content:
>> >> proj:       0
>> >> zone:       0
>> >> north:      1
>> >> south:      0
>> >> east:       1
>> >> west:       0
>> >> cols:       1
>> >> rows:       1
>> >> e-w resol:  1
>> >> n-s resol:  1
>> >> top:        1
>> >> bottom:     0
>> >> cols3:      1
>> >> rows3:      1
>> >> depths:     1
>> >> e-w resol3: 1
>> >> n-s resol3: 1
>> >> t-b resol:  1
>> >> The env variables I'm using are:
>> >> export PYTHONPATH='/usr/lib/grass70/etc/python'
>> >> export GISRC='/tmp/tmp9YVf_N/gisrc'
>> >> export GRASS_VERSION='7.0.0'
>> >> export
>> PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
>> >> export GIS_LOCK=$
>> >> export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
>> >> export GISBASE='/usr/lib/grass70'
>> >> Whatevere shapefile I try to import I obtain a segfault.
>> >> This is the test command:
>> >> :/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
>> >> location=workLocation -ie
>> >> If I add the VAR file with:
>> >> DB_DRIVER: sqlite
>> >> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>> >> eveythign works fine.
>> >> giovanni
>> >> 2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> >>> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com>
>> wrote:
>> >>> > I'm getting segmentation faults in case I run a command on a
>> location
>> >>> > missing the VAR file.
>> >>> On which OS, which GRASS version?
>> >>> > I thought it was optional, as it's said here:
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
>> >>> Please post a reproducible example, thanks.
>> >>> Markus
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150218/fcf2235e/attachment-0001.html>
