[GRASS-user] Is the location's VAR file required?
Markus Metz
markus.metz.giswork at gmail.com
Wed Feb 18 13:34:32 PST 2015
On Wed, Feb 18, 2015 at 10:14 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Wed, Feb 18, 2015 at 4:01 PM, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
>> On Wed, Feb 18, 2015 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > I think we should really implement #2579 [1] in one way or the other.
>> > This
>> > would make custom setups [2] not necessary for most cases. What do you
>> > think? What should be the command line parameters?
>> Importing a shapefile to a new location without a VAR file works for
>> me, and I think we should find out why it does not work for Giovanni.
>> His approach should (must) work as it is.
> Could this be related?
> http://lists.osgeo.org/pipermail/grass-dev/2014-September/070639.html
I think not because I started GRASS in a new location, VAR was
created, then I deleted it, then I ran v.in.ogr successfully, and VAR
was recreated again. v.in.ogr works for me without a VAR file present.
Markus M
> Anna
>> Markus M
>> > Vaclav
>> > [1] http://trac.osgeo.org/grass/ticket/2579
>> > [2]
>> > http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
>> > On Wed, Feb 18, 2015 at 1:26 PM, G. Allegri <giohappy at gmail.com> wrote:
>> >> Hi Markus,
>> >> I wrote the details in another recent email and I forgot to write the
>> >> here, sorry.
>> >> GRASS 7.0.0 RC1 on Ubuntu 14.04.
>> >> I'm creating a temporary database with an empty start location, with no
>> >> CRS defined (proj code 0, i.e. XY).
>> >> My location contains only the the WIND and DEFAULT_WIND files with the
>> >> following content:
>> >> proj: 0
>> >> zone: 0
>> >> north: 1
>> >> south: 0
>> >> east: 1
>> >> west: 0
>> >> cols: 1
>> >> rows: 1
>> >> e-w resol: 1
>> >> n-s resol: 1
>> >> top: 1
>> >> bottom: 0
>> >> cols3: 1
>> >> rows3: 1
>> >> depths: 1
>> >> e-w resol3: 1
>> >> n-s resol3: 1
>> >> t-b resol: 1
>> >> The env variables I'm using are:
>> >> export PYTHONPATH='/usr/lib/grass70/etc/python'
>> >> export GISRC='/tmp/tmp9YVf_N/gisrc'
>> >> export GRASS_VERSION='7.0.0'
>> >> export
>> >> PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
>> >> export GIS_LOCK=$
>> >> export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
>> >> export GISBASE='/usr/lib/grass70'
>> >> Whatevere shapefile I try to import I obtain a segfault.
>> >> This is the test command:
>> >> :/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
>> >> location=workLocation -ie
>> >> If I add the VAR file with:
>> >> DB_DRIVER: sqlite
>> >> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>> >> eveythign works fine.
>> >> giovanni
>> >> 2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> >>> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com>
>> >>> wrote:
>> >>> > I'm getting segmentation faults in case I run a command on a
>> >>> > location
>> >>> > missing the VAR file.
>> >>> On which OS, which GRASS version?
>> >>> > I thought it was optional, as it's said here:
>> >>> > http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
>> >>> Please post a reproducible example, thanks.
>> >>> Markus
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
