[GRASS-user] Is the location's VAR file required?
G. Allegri
giohappy at gmail.com
Wed Feb 18 14:30:40 PST 2015
I confirm that trunks doesn't causes segfault. Same mapset and location.
Now I have to figure our why the import doesn't happen:
v.in.ogr input=/mnt/data/centroids.shp location=workLocation
output=centroids -ie
The location is created but is empty.
Thr same shape is correctly imported from GUI.
I will double check and try it again...
Il 18/feb/2015 22:34 "Markus Metz" <markus.metz.giswork at gmail.com> ha
scritto:
> On Wed, Feb 18, 2015 at 10:14 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > On Wed, Feb 18, 2015 at 4:01 PM, Markus Metz <
> > wrote:
> >> On Wed, Feb 18, 2015 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
> >> wrote:
> >> > I think we should really implement #2579 [1] in one way or the other.
> >> > This
> >> > would make custom setups [2] not necessary for most cases. What do you
> >> > think? What should be the command line parameters?
> >> Importing a shapefile to a new location without a VAR file works for
> >> me, and I think we should find out why it does not work for Giovanni.
> >> His approach should (must) work as it is.
> > Could this be related?
> > http://lists.osgeo.org/pipermail/grass-dev/2014-September/070639.html
> I think not because I started GRASS in a new location, VAR was
> created, then I deleted it, then I ran v.in.ogr successfully, and VAR
> was recreated again. v.in.ogr works for me without a VAR file present.
> Markus M
> > Anna
> >> Markus M
> >> > Vaclav
> >> > [1] http://trac.osgeo.org/grass/ticket/2579
> >> > [2]
> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
> >> > On Wed, Feb 18, 2015 at 1:26 PM, G. Allegri <giohappy at gmail.com>
> wrote:
> >> >> Hi Markus,
> >> >> I wrote the details in another recent email and I forgot to write the
> >> >> here, sorry.
> >> >> GRASS 7.0.0 RC1 on Ubuntu 14.04.
> >> >> I'm creating a temporary database with an empty start location, with
> no
> >> >> CRS defined (proj code 0, i.e. XY).
> >> >> My location contains only the the WIND and DEFAULT_WIND files with
> the
> >> >> following content:
> >> >> proj: 0
> >> >> zone: 0
> >> >> north: 1
> >> >> south: 0
> >> >> east: 1
> >> >> west: 0
> >> >> cols: 1
> >> >> rows: 1
> >> >> e-w resol: 1
> >> >> n-s resol: 1
> >> >> top: 1
> >> >> bottom: 0
> >> >> cols3: 1
> >> >> rows3: 1
> >> >> depths: 1
> >> >> e-w resol3: 1
> >> >> n-s resol3: 1
> >> >> t-b resol: 1
> >> >> The env variables I'm using are:
> >> >> export PYTHONPATH='/usr/lib/grass70/etc/python'
> >> >> export GISRC='/tmp/tmp9YVf_N/gisrc'
> >> >> export GRASS_VERSION='7.0.0'
> >> >> export
> PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
> >> >> export GIS_LOCK=$
> >> >> export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
> >> >> export GISBASE='/usr/lib/grass70'
> >> >> Whatevere shapefile I try to import I obtain a segfault.
> >> >> This is the test command:
> >> >> :/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
> >> >> location=workLocation -ie
> >> >> If I add the VAR file with:
> >> >> DB_DRIVER: sqlite
> >> >> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> >> >> eveythign works fine.
> >> >> giovanni
> >> >> 2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> >> >>> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com>
> >> >>> wrote:
> >> >>> > I'm getting segmentation faults in case I run a command on a
> >> >>> > location
> >> >>> > missing the VAR file.
> >> >>> On which OS, which GRASS version?
> >> >>> > I thought it was optional, as it's said here:
> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
> >> >>> Please post a reproducible example, thanks.
> >> >>> Markus
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150218/e61afe31/attachment.html>
