[GRASS-user] Default method of rasterizing in v.to.rast
Nikos Alexandris
nik at nikosalexandris.net
Mon Feb 23 06:31:48 PST 2015
RichardCooper wrote:
> I'm trying to determine the default method of rasterization used by
> v.to
> rast.
> In the v.to.rast manual it states in relation to the -d option, that
> 'All
> cells touched by the line will be set, not only those on the render
> path',
> but I'm not certain which method is being used by default.
> I came across a paper by Biagi and Negretti
> <http://geomatica.como.polimi.it/workbooks/n2/articoli/lbmn.pdf> *
> which
> describes how by default vectors are rasterized in GRASS 5. The
> latter
> authors refer to the 'center' method as being the standard GRASS
> command in
> 5.0 (p. 4). Is this used in GRASS 7? From my observation (in the Map
> Display), by default, vector area appear to be rasterized if the
> center of
> the grid cell falls within the area boundary?
> I haven't checked through the code,
Hints:
grep -nr centroid * # inside the module's source code directory
Binary file OBJ.x86_64-unknown-linux-gnu/vect2rast.o matches
Binary file OBJ.x86_64-unknown-linux-gnu/do_lines.o matches
Binary file OBJ.x86_64-unknown-linux-gnu/do_areas.o matches
Binary file OBJ.x86_64-unknown-linux-gnu/support.o matches
do_areas.c:42: if (ISNULL(&cat)) { /* No centroid or no category
do_areas.c:94: int i, centroid, nareas_selected;
do_areas.c:114: centroid = Vect_get_area_centroid(Map, i + 1);
do_areas.c:116: if (centroid <= 0) {
do_areas.c:117: G_debug(2,_("Area without centroid (OK for
island)"));
do_areas.c:120: Vect_read_line(Map, NULL, Cats, centroid);
do_areas.c:127: G_debug(2, _("Area centroid without
category"));
do_areas.c:131: /* field < 1, process all areas with centroid
v.to.rast.html:41:Labeled areas and/or centroids will produce filled
raster coverages with edges
v.to.rast.html:49:Points and orphaned centroids will be converted into
single cells on the
vect2rast.c:219: /* maximum possible numer of areas: number of
centroids
vect2rast.c:221: * number of areas with centroid that are within
cat constraint
Nikos
> but maybe someone has some knowledge on
> the history of v.to.rast?
> Cheers,
> Richard
> *http://geomatica.como.polimi.it/workbooks/n2/articoli/lbmn.pdf
