[GRASS-user] Odd r.mask behaviour (v6.4.2 and v6.4.3)
Michael Spencer spencer.mike.r at gmail.com
Wed Feb 25 07:56:16 PST 2015
No problem.
The working mask is based on a DEM (
http://www.ordnancesurvey.co.uk/business-and-government/products/terrain-50.html),
created with:
r.reclass input=DEM at Permanent output=DEM_reclass at Permanent rules=elev.txt
elev.txt
0 thru 150 = 0
150 thru 300 = 150
300 thru 450 = 300
450 thru 600 = 450
600 thru 750 = 600
750 thru 900 = 750
900 thru 1050 = 900
1050 thru 1200 = 1050
1200 thru 1500 = 1200
The none working mask uses a raster based on the above, created using:
# in A mapset
r.mask -o input=viewshed maskcasts='*'
r.mapcalc 'subset=DEM_reclass at Permanent'
Strictly speaking, this step was done via spgrass6 as I have 145 subsets to
apply:
lapply(st[,1], function(i){
   # Which site?
   print(i)
   # Mask to LOS
   system(paste0("r.mask -o input=", i, " maskcats='*'"))
   # Reclass via mapcalc
   system(paste0("r.mapcalc '", i, "_elev=Terrain50_SSGB at PERMANENT'"))
However, The rasters I want to mask exist in B mapset and I understand the
mask and rasters to be applied to need to be in the same mapset, so I have:
g.copy rast='subset at A',subset
prior to applying the mask
On Wed, Feb 25, 2015 at 3:20 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Wed, Feb 25, 2015 at 9:58 AM, Michael Spencer <spencer.mike.r at gmail.com
> > wrote:
>> I'm getting odd results from using r.mask. The expected behaviour is that
>> when applied it masks off all rasters in the working mapset, however what
>> I'm getting is it only masks off the raster used as a mask.
>> This doesn't happen when I create a mask using a different raster, this
>> behaves as expected and masks all rasters in the current mapset.
>> Detail:
>> Working mask: reclass of another raster
>> Not working mask: subset of above, created by applying a mask and using
>> mapcalc (newmap=oldmap).
> Could you post the actual commands you used?
> Thanks,
> Anna
>> Any help greatly appreciated!
>> Mike
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150225/7a27c6c5/attachment.html>
