[GRASS-user] Odd r.mask behaviour (v6.4.2 and v6.4.3)
Michael Spencer
spencer.mike.r at gmail.com
Wed Feb 25 08:41:04 PST 2015
I've narrowed the problem down to creating a masked copy using r.mapcalc.
The LOS output works fine, but the LOS with elevation values does not. Is
there another way to create this? Or can I apply a mask based on the area
of one raster and the value of another?
Ta,
Mike
On Wed, Feb 25, 2015 at 3:56 PM, Michael Spencer <spencer.mike.r at gmail.com>
wrote:
> No problem.
> The working mask is based on a DEM (
> http://www.ordnancesurvey.co.uk/business-and-government/products/terrain-50.html),
> created with:
> r.reclass input=DEM at Permanent output=DEM_reclass at Permanent rules=elev.txt
> elev.txt
> 0 thru 150 = 0
> 150 thru 300 = 150
> 300 thru 450 = 300
> 450 thru 600 = 450
> 600 thru 750 = 600
> 750 thru 900 = 750
> 900 thru 1050 = 900
> 1050 thru 1200 = 1050
> 1200 thru 1500 = 1200
> The none working mask uses a raster based on the above, created using:
> # in A mapset
> r.mask -o input=viewshed maskcasts='*'
> r.mapcalc 'subset=DEM_reclass at Permanent'
> Strictly speaking, this step was done via spgrass6 as I have 145 subsets
> to apply:
> lapply(st[,1], function(i){
> # Which site?
> print(i)
> # Mask to LOS
> system(paste0("r.mask -o input=", i, " maskcats='*'"))
> # Reclass via mapcalc
> system(paste0("r.mapcalc '", i, "_elev=Terrain50_SSGB at PERMANENT'"))
> However, The rasters I want to mask exist in B mapset and I understand the
> mask and rasters to be applied to need to be in the same mapset, so I have:
> g.copy rast='subset at A',subset
> prior to applying the mask
> On Wed, Feb 25, 2015 at 3:20 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Wed, Feb 25, 2015 at 9:58 AM, Michael Spencer <
>> spencer.mike.r at gmail.com> wrote:
>>> I'm getting odd results from using r.mask. The expected behaviour is
>>> that when applied it masks off all rasters in the working mapset, however
>>> what I'm getting is it only masks off the raster used as a mask.
>>> This doesn't happen when I create a mask using a different raster, this
>>> behaves as expected and masks all rasters in the current mapset.
>>> Detail:
>>> Working mask: reclass of another raster
>>> Not working mask: subset of above, created by applying a mask and using
>>> mapcalc (newmap=oldmap).
>> Could you post the actual commands you used?
>> Thanks,
>> Anna
>>> Any help greatly appreciated!
>>> Mike
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150225/2af66ab1/attachment.html>
