[GRASS-user] Lost in encoding problem, v.in.ogr
Daniel Victoria daniel.victoria at gmail.com
Thu Feb 26 10:35:38 PST 2015
Hi List,
I'm having trouble importing a shapefile with v.in.ogr that has some
accented characters (like não, rodoviária).
The shapefile opend fine in QGIS and I can open the dbf on libreoffice,
setting the encoding to (windows-1252/winlatin 1).
I imported the shapefile and if I run v.db.select or if I open the
attribute data, accented characters are messed up. However, when I try to
query the layer, an error message (png attached) will show telling me to
check database settings and then gives me the reason for the failure. I can
then see that the queried attributes in this windows all have the accented
character.
Has anyone had any luck with accented characters in v.in.ogr? I tried
changing the encoding option in v.in.ogr but could not get it to work.
I'm using grass7 from OSGeo4Win. Attached is the shapefile that I'm trying
to import.
Thanks
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150226/79bd7568/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150226/79bd7568/attachment-0001.obj>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150226/79bd7568/attachment-0001.png>
