[GRASS-user] Lost in encoding problem, v.in.ogr
Daniel Victoria daniel.victoria at gmail.com
Fri Feb 27 03:15:34 PST 2015
Thanks Ana,
Setting the attributes / encoding to windows-1252 fixed the query results
windows problem. But as you mentioned, it did not help with the Attribute
table manager.
Also, v.db.select works from the command console in the layer manager but
it does not work in the windows command line
Cheers
Daneil
On Fri, Feb 27, 2015 at 12:16 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Feb 26, 2015 at 1:35 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Hi List,
>> I'm having trouble importing a shapefile with v.in.ogr that has some
>> accented characters (like não, rodoviária).
>> The shapefile opend fine in QGIS and I can open the dbf on libreoffice,
>> setting the encoding to (windows-1252/winlatin 1).
>> I imported the shapefile and if I run v.db.select or if I open the
>> attribute data, accented characters are messed up. However, when I try to
>> query the layer, an error message (png attached) will show telling me to
>> check database settings and then gives me the reason for the failure. I can
>> then see that the queried attributes in this windows all have the accented
>> character.
>> Has anyone had any luck with accented characters in v.in.ogr? I tried
>> changing the encoding option in v.in.ogr but could not get it to work.
>> I'm using grass7 from OSGeo4Win. Attached is the shapefile that I'm
>> trying to import.
> Try to specify the encoding in GUI settings -> Attributes -> encoding ->
> windows-1252.
> But it probably won't help with displaying in Attribute table manager.
> To developers:
> I am totally confused how the attribute encoding is currently implemented.
> The ATM fails to display the characters correctly since environmental
> variable GRASS_DB_ENCODING is not set. I can't find any place where it
> would be set. The list of grass variable says that there is GRASS gisenv
> variable GRASS_DB_ENCODING. Grep shows usage of GRASS_DB_ENCODING only in
> gui and it is not set anywhere. Any idea someone?
> Anna
>> Thanks
>> Daniel
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150227/e12c8d3b/attachment.html>
