[GRASS-user] g.extension gives an error when installing	r.prominence
    Markus Neteler
    neteler at osgeo.org
    Wed Jan  7 14:39:10 PST 2015
On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com> wrote:
> When I try to install the r.prominence extension I get the following error:
> g.extension.py -i extension=r.prominence
> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
> WARNING: GRASS_ADDON_PATH has more items, using first defined -
> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
> ld: library not found for -lintl
> clang: error: linker command failed with exit code 1 (use -v
> to see invocation)
> ERROR: Compilation failed, sorry. Please check above error messages.
On Wed, Jan 7, 2015 at 10:37 PM, Thayer Young <thayeray at yahoo.com> wrote:
> I am on Mac OS 10.10.  From the About GRASS GIS window:
> GRASS GIS 6.4.5svn, SVN Revision 61583M, GIS Library Revision 50937
> (2012-02-25), Python: 2.7.6, wxPython: 2.8.12.1
> I installed it using the Michael Barton snapshot , but I installed it using
> the Kyng Chaos frameworks (I tried both GUIs and went with the Barton
> version).
I see. So I add Michael in CC, perhaps he remembers the solution since
a similar issue was discussed last year:
http://lists.osgeo.org/pipermail/grass-dev/2014-April/068136.html
(and related messages).
Markus
