[GRASS-user] g.extension gives an error when installing r.prominence
Thayer Young
thayeray at yahoo.com
Wed Jan 7 13:37:43 PST 2015
>Date: Tue, 6 Jan 2015 23:47:57 +0100
>From: Markus Neteler <neteler at osgeo.org>
>To: Thayer Young <thayeray at yahoo.com>
>Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>Subject: Re: [GRASS-user] g.extension gives an error when installing
> r.prominence
>Message-ID:
> <CALFmHhvGgaEq_zBD_fTWry0jRgH->p0UaPOL+O+2bhX20r81hVA at mail.gmail.com>
>Content-Type: text/plain; charset=UTF-8
>On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com> wrote:
>> When I try to install the r.prominence extension I get the following error:
>> g.extension.py -i extension=r.prominence
>> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
>> WARNING: GRASS_ADDON_PATH has more items, using first defined -
>> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
>> ld: library not found for -lintl
>> clang: error: linker command failed with exit code 1 (use -v
>> to see invocation)
>> ERROR: Compilation failed, sorry. Please check above error messages.
>This is strange, for Windows g.extension should download a precompiled
>"r.prominence.exe".
>Which GRASS GIS 6.4.x version do you use precisely? And on which
>Windows Version?
>Markus
I am on Mac OS 10.10. From the About GRASS GIS window:
GRASS GIS 6.4.5svn, SVN Revision 61583M, GIS Library Revision 50937 (2012-02-25), Python: 2.7.6, wxPython: 2.8.12.1
I installed it using the Michael Barton snapshot , but I installed it using the Kyng Chaos frameworks (I tried both GUIs and went with the Barton version).
-Thayer
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150107/6c8ad081/attachment.html>
