[GRASS-user] GRASS 7 temporal module under Windows
Moyano Capilla, Jose Eduardo
josmoy at ceh.ac.uk
Wed Jan 7 10:24:03 PST 2015
Yes! I had to uninstall the version I was working with (grass7.0.0.svn) and installed grass7.0.0beta3 and with that one it worked. I must add that in the end I got an error when I tried to create an animation, that was my objective, but I could create the temporal datasets and work with them.
I hope this helps.
Cheers,
Jose.
-----Original Message-----
Sent: 07 January 2015 16:29
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] GRASS 7 temporal module under Windows
Moyano Capilla, Jose Eduardo <josmoy <at> ceh.ac.uk> writes:
> Hi all,
> I am pretty new with GRASS, so sorry for the more than likely stupid
question.
> I am trying to use the new temporal module in GRASS 7 running under
Windows 7 (I am waiting for authorization to use it under Linux). I am following the example presented in the FOSS4G 2014 workshop
(http://fatra.cnr.ncsu.edu/temporal-grass-workshop/)
> but when I try to register the temporal dataset I get an error. It
has a lot of lines, but I think the key is in the following:
> RuntimeError:
> Attempt to start a new process before the current process
> has finished its bootstrapping phase.
> This probably means that you are on Windows and you have
> forgotten to use the proper idiom in the main
> module:
> if __name__ == '__main__':
> freeze_support()
> The "freeze_support()" line can be omitted if the program
> is not going to be frozen to produce a Windows executable.
> I am just running the commands through the GUI, should I create a
python script to resolve that “freeze_support()” issue? As I said, I am pretty new and that would take some time, that’s why I prefer to ask first if that’s the way...
> Thank you in advance!!
> Jose
> This message (and any attachments) is for the recipient only. NERC is
subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt
> from release under the Act. Any material supplied to NERC may be
stored in an electronic records management system.
> grass-user mailing list
> grass-user <at> lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
I've encountered the same problem, have you solved it?
Regards,
Ariel
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
