[GRASS-user] grass-user Digest, Vol 105, Issue 9
Thayer Young
thayeray at yahoo.com
Thu Jan 8 07:33:30 PST 2015
Ben,
Thanks for your response. Unfortunately, I already have both Homebrew and gettext installed. I am still unable to install r.prominence or r.findtheriver.
I will try reading the "Notes on GRASS Programming" in "Opensource GIS" and see if I can compile it using Eclipse. -Thayer
Date: Thu, 08 Jan 2015 15:34:21 +0100
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] g.extension gives an error when installing
r.prominence
Message-ID: <54AE956D.8080506 at fastmail.fm>
Content-Type: text/plain; charset=windows-1252
Thayer,
>> On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com
> <mailto:thayeray at yahoo.com>> wrote:
>> When I try to install the r.prominence extension I get the following
> error:
>> g.extension.py -i extension=r.prominence
>> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
>> WARNING: GRASS_ADDON_PATH has more items, using first defined -
>> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
>> ld: library not found for -lintl
>> clang: error: linker command failed with exit code 1 (use -v
>> to see invocation)
>> ERROR: Compilation failed, sorry. Please check above error messages.
Which version of Mac OS X are you on?
I recall having a similar problem, related to "gettext",
with OS 10.9.
In my case, this solved the problem (requires an
Internet connection):
1. Go to http://brew.sh/ and install "brew", then:
2. in the Terminal, issue:
brew install gettext
3. Try compiling again.
Best,
Ben
> On Wed, Jan 7, 2015 at 10:37 PM, Thayer Young <thayeray at yahoo.com
>> I am on Mac OS 10.10. From the About GRASS GIS window:
>> GRASS GIS 6.4.5svn, SVN Revision 61583M, GIS Library Revision 50937
>> (2012-02-25), Python: 2.7.6, wxPython: 2.8.12.1
>> I installed it using the Michael Barton snapshot , but I installed it
> using
>> the Kyng Chaos frameworks (I tried both GUIs and went with the Barton
>> version).
> I see. So I add Michael in CC, perhaps he remembers the solution since
> a similar issue was discussed last year:
> http://lists.osgeo.org/pipermail/grass-dev/2014-April/068136.html
> (and related messages).
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150108/11e64523/attachment.html>
