[GRASS-user] grass-user Digest, Vol 105, Issue 9
Benjamin Ducke benducke at fastmail.fm
Thu Jan 8 07:46:57 PST 2015
The problem is that the linker does not find
"lintl". Search your file system to see
if and where you have a copy of "libintl.dylib".
If it exists somewhere, then you need to tell
the linker where it is. E.g. if you find it
in "/usr/local/lib", then add that path to
the linker search path:
DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH:/usr/local/lib"
... before invoking "g.extension".
Solving this linker issue will probably get you there
faster than trying to set up a complete environment
for compiling GRASS modules.
Cheers,
Ben
On 08/01/15 16:33, Thayer Young wrote:
> Ben,
> Thanks for your response.  Unfortunately, I already have both Homebrew
> and gettext installed.  I am still unable to install r.prominence or
> r.findtheriver.
> I will try reading the "Notes on GRASS Programming" in "Opensource GIS"
> and see if I can compile it using Eclipse.
> -Thayer
> Date: Thu, 08 Jan 2015 15:34:21 +0100
> From: Benjamin Ducke <benducke at fastmail.fm <mailto:benducke at fastmail.fm>>
> To: grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] g.extension gives an error when installing
>     r.prominence
> Message-ID: <54AE956D.8080506 at fastmail.fm
> <mailto:54AE956D.8080506 at fastmail.fm>>
> Content-Type: text/plain; charset=windows-1252
> Thayer,
>>> On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com
> <mailto:thayeray at yahoo.com>
>> <mailto:thayeray at yahoo.com <mailto:thayeray at yahoo.com>>> wrote:
>>> When I try to install the r.prominence extension I get the following
>> error:
>>> g.extension.py -i extension=r.prominence
>>> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
>>> WARNING: GRASS_ADDON_PATH has more items, using first defined -
>>> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
>>> ld: library not found for -lintl
>>> clang: error: linker command failed with exit code 1 (use -v
>>> to see invocation)
>>> ERROR: Compilation failed, sorry. Please check above error messages.
> Which version of Mac OS X are you on?
> I recall having a similar problem, related to "gettext",
> with OS 10.9.
> In my case, this solved the problem (requires an
> Internet connection):
> 1. Go to http://brew.sh/ <http://brew.sh/>and install "brew", then:
> 2. in the Terminal, issue:
>   brew install gettext
> 3. Try compiling again.
> Best,
> Ben
>> On Wed, Jan 7, 2015 at 10:37 PM, Thayer Young <thayeray at yahoo.com
>>> I am on Mac OS 10.10.  From the About GRASS GIS window:
>>> GRASS GIS 6.4.5svn, SVN Revision 61583M, GIS Library Revision 50937
>>> (2012-02-25), Python: 2.7.6, wxPython: 2.8.12.1
>>> I installed it using the Michael Barton snapshot , but I installed it
>> using
>>> the Kyng Chaos frameworks (I tried both GUIs and went with the Barton
>>> version).
>> I see. So I add Michael in CC, perhaps he remembers the solution since
>> a similar issue was discussed last year:
>> http://lists.osgeo.org/pipermail/grass-dev/2014-April/068136.html
>> (and related messages).
>> Markus
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr. Benjamin Ducke
> {*} Geospatial Consultant
> {*} GIS Developer
> Spatial technology for the masses, not the classes:
> experience free and open source GIS at http://gvsigce.org
> <http://gvsigce.org/>
Dr. Benjamin Ducke
{*} GIS Developer
