[GRASS-user] r.terraflow on massive DEM
    Markus Metz
    markus.metz.giswork at gmail.com
    Tue Jan 13 11:40:24 PST 2015
On Tue, Jan 13, 2015 at 7:52 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Now, the thing is, my main interest is to fill the voids in the SRTM data.
> So I though about using r.terraflow to get the filled elevation. Should I
> continue on that path or would it be better to use r.fill.null on a large
> dataset?
r.terraflow does not fill voids, it fills sinks. Use SRTM v3 [0], this
is gap-filled. Using r.fill.null on SRTM v2 will not give you the same
quality. r.terraflow has a limit on the number of rows and columns
(max 32,767 each). r.watershed also has a limit on the number of rows
and columns, but that is max 2,147,483,647 each. In any case, you
should use GRASS 7 for such large datasets.
Markus M
[0] https://lpdaac.usgs.gov/products/measures_products_table/srtmgl3
> Thanks
> Daniel
> On Tue, Jan 13, 2015 at 1:46 PM, Daniel Victoria <daniel.victoria at gmail.com>
> wrote:
>> Charlie,
>> I just downloaded some SRTM 1arc sec. from EarthExplorer. The data is
>> supplied in 3 different file types, GeoTIFF, DTED or BIL and they are all in
>> Integer values (Int16). No floating point elevation values.
>> Cheers
>> Daniel
>> On Tue, Jan 13, 2015 at 12:12 PM, Charlie Shobe <chsh5846 at colorado.edu>
>> wrote:
>>> Hi Daniel,
>>> I believe that SRTM data does in fact provide floating point elevation
>>> values, so you may want to try working with the DEM as type FCELL from the
>>> very beginning. I don't know if this will help solve your problem, but the
>>> last time I brought in SRTM (1 arc second) data it was type FCELL and
>>> contained several decimal places of precision.
>>> Good luck,
>>> Charlie
>>> On Jan 13, 2015, at 4:00 AM, Daniel Victoria <daniel.victoria at gmail.com>
>>> wrote:
>>> Stephan, I'll give r.watershed a try and let it run for a couple of days.
>>> Thanks
>>> Thayer, I used r.recode because the person that sent me the data messed
>>> up the null values. So in order to fix that I did:
>>> 1) use r.external to bring the data to Grass
>>> 2) fix null values with r.recode, which was faster than r.null
>>> But I gave up on that path and since imported the data (r.in.gdal) and
>>> fixed the null values with r.null.
>>> I'm also using integer values (CELL type) because from what I heard, SRTM
>>> does not provide floating point data.
>>> Now I tried to run r.terraflow but I got a type error which asked me to
>>> use r.terraflow.short. Since I don't have that command in my grass
>>> instalatin, I converted the SRTM data to float. But that was to no avail
>>> since it's now giving me a dimensions type overflow error and asking me to
>>> change the dimension_type and recompile.
>>> I'll give r.watershed a try. If that does not work, I'll see if I can
>>> recompile.
>>> Thanks
>>> Daniel
>>> On Mon, Jan 12, 2015 at 9:22 PM, Thayer Young <thayeray at yahoo.com> wrote:
>>>> With regards to the size of DEM, if you can get the command to run it
>>>> may take several days to finish, this is more than twice the size of the
>>>> Washington State DEM that took the authors 33 hours in 2003 (Arge, Chase,
>>>> Halpin, Toma, Urban, Vitter, Wickremesinghe  Efficient Flow Computation on
>>>> Massive Grid Terrain Datasets Geoinformatica Volume 7 Issue 4, December 2003
>>>> Pages 283 - 313 ).  My mid-2014 computer runs at about twice the speed
>>>> quoted in the paper.
>>>> Did you r.recode it to make it smaller?  In flat areas you need the data
>>>> contained after the decimal point to allow the flow a chance to make it down
>>>> hill, otherwise you can get streams going no where near where they do in
>>>> real life.  I have never tried running r.terraflow on an integer raster, I
>>>> know that it works on decimal rasters.
>>>> -Thayer
>>>> ________________________________
>>>> Date: Mon, 12 Jan 2015 09:59:40 -0200
>>>> From: Daniel Victoria <daniel.victoria at gmail.com>
>>>> To: grass <grass-user at lists.osgeo.org>
>>>> Subject: [GRASS-user] r.terraflow on massive DEM
>>>> Message-ID:
>>>>     <CA+irsJjf7xhWgU968D+4+xc2YGJ=_n4xJtP0_WeU1ZpoRTt9ng at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hi list,
>>>> I'm trying to run r.terraflow on a very large DEM but I wander if it's
>>>> __too large__.
>>>> The region dimensions are:
>>>> ncol=141114
>>>> nrow=140487
>>>> Data type = CELL
>>>> The map is actually a reclass map of a raster that I imported using
>>>> r.external.
>>>> When I run r.terraflow I get:
>>>> r.terraflow elevation=srtm_brasil at PERMANENT filled=srtm_fill
>>>> direction=flowdir swatershed=sink accumulation=flowacc tci=srtm_tci
>>>> directory=E:\terraflow_temp
>>>> WARNING: raster srtm_brasil is of type CELL_TYPE --you should use
>>>> r.terraflow.short
>>>> ERROR: [nrows=140487, ncols=141114] dimension_type overflow -- change
>>>> (Mon Jan 12 09:57:18 2015) Command finished (0
>>>> sec)
>>>> However, I don't have an r.terraflow.short command
>>>> I'm running Grass 7.0.0beta4 from OsGeo4W
>>>> Cheers
>>>> Daniel
>>>> -------------- next part --------------
>>>> An HTML attachment was scrubbed...
>>>> URL:
>>>> <http://lists.osgeo.org/pipermail/grass-user/attachments/20150112/a27c139f/attachment-0001.html>
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> End of grass-user Digest, Vol 105, Issue 16
