[GRASS-user] r.terraflow on massive DEM
Daniel Victoria daniel.victoria at gmail.com
Wed Jan 14 02:48:58 PST 2015
Hi Markus,
I was using r.terraflow because I had converted my voids to negative values
while the areas outside the country where set to null.
But the data is proving to be too big and I'll just skip the gap-filling
for now. Might do it later on, filling the gaps in the import process.
The SRTM v3 you pointed out is very good but it's the 3-arcsec resolution.
I'm working with the 1-arcsec res.
Cheers and thanks
Daniel
On Tue, Jan 13, 2015 at 5:40 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Tue, Jan 13, 2015 at 7:52 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
> > Now, the thing is, my main interest is to fill the voids in the SRTM
> data.
> > So I though about using r.terraflow to get the filled elevation. Should I
> > continue on that path or would it be better to use r.fill.null on a large
> > dataset?
> r.terraflow does not fill voids, it fills sinks. Use SRTM v3 [0], this
> is gap-filled. Using r.fill.null on SRTM v2 will not give you the same
> quality. r.terraflow has a limit on the number of rows and columns
> (max 32,767 each). r.watershed also has a limit on the number of rows
> and columns, but that is max 2,147,483,647 each. In any case, you
> should use GRASS 7 for such large datasets.
> Markus M
> [0] https://lpdaac.usgs.gov/products/measures_products_table/srtmgl3
> > Thanks
> > Daniel
> > On Tue, Jan 13, 2015 at 1:46 PM, Daniel Victoria <
> > wrote:
> >> Charlie,
> >> I just downloaded some SRTM 1arc sec. from EarthExplorer. The data is
> >> supplied in 3 different file types, GeoTIFF, DTED or BIL and they are
> all in
> >> Integer values (Int16). No floating point elevation values.
> >> Cheers
> >> Daniel
> >> On Tue, Jan 13, 2015 at 12:12 PM, Charlie Shobe <chsh5846 at colorado.edu>
> >> wrote:
> >>> Hi Daniel,
> >>> I believe that SRTM data does in fact provide floating point elevation
> >>> values, so you may want to try working with the DEM as type FCELL from
> the
> >>> very beginning. I don't know if this will help solve your problem, but
> the
> >>> last time I brought in SRTM (1 arc second) data it was type FCELL and
> >>> contained several decimal places of precision.
> >>> Good luck,
> >>> Charlie
> >>> On Jan 13, 2015, at 4:00 AM, Daniel Victoria <
> >>> wrote:
> >>> Stephan, I'll give r.watershed a try and let it run for a couple of
> days.
> >>> Thanks
> >>> Thayer, I used r.recode because the person that sent me the data messed
> >>> up the null values. So in order to fix that I did:
> >>> 1) use r.external to bring the data to Grass
> >>> 2) fix null values with r.recode, which was faster than r.null
> >>> But I gave up on that path and since imported the data (r.in.gdal) and
> >>> fixed the null values with r.null.
> >>> I'm also using integer values (CELL type) because from what I heard,
> SRTM
> >>> does not provide floating point data.
> >>> Now I tried to run r.terraflow but I got a type error which asked me to
> >>> use r.terraflow.short. Since I don't have that command in my grass
> >>> instalatin, I converted the SRTM data to float. But that was to no
> avail
> >>> since it's now giving me a dimensions type overflow error and asking
> me to
> >>> change the dimension_type and recompile.
> >>> I'll give r.watershed a try. If that does not work, I'll see if I can
> >>> recompile.
> >>> Thanks
> >>> Daniel
> >>> On Mon, Jan 12, 2015 at 9:22 PM, Thayer Young <thayeray at yahoo.com>
> wrote:
> >>>> With regards to the size of DEM, if you can get the command to run it
> >>>> may take several days to finish, this is more than twice the size of
> the
> >>>> Washington State DEM that took the authors 33 hours in 2003 (Arge,
> Chase,
> >>>> Halpin, Toma, Urban, Vitter, Wickremesinghe  Efficient Flow
> Computation on
> >>>> Massive Grid Terrain Datasets Geoinformatica Volume 7 Issue 4,
> December 2003
> >>>> Pages 283 - 313 ).  My mid-2014 computer runs at about twice the speed
> >>>> quoted in the paper.
> >>>> Did you r.recode it to make it smaller?  In flat areas you need the
> data
> >>>> contained after the decimal point to allow the flow a chance to make
> it down
> >>>> hill, otherwise you can get streams going no where near where they do
> in
> >>>> real life.  I have never tried running r.terraflow on an integer
> raster, I
> >>>> know that it works on decimal rasters.
> >>>> -Thayer
> >>>> ________________________________
> >>>> Date: Mon, 12 Jan 2015 09:59:40 -0200
> >>>> From: Daniel Victoria <daniel.victoria at gmail.com>
> >>>> To: grass <grass-user at lists.osgeo.org>
> >>>> Subject: [GRASS-user] r.terraflow on massive DEM
> >>>> Message-ID:
> >>>>     <CA+irsJjf7xhWgU968D+4+xc2YGJ=_
> n4xJtP0_WeU1ZpoRTt9ng at mail.gmail.com>
> >>>> Content-Type: text/plain; charset="utf-8"
> >>>> Hi list,
> >>>> I'm trying to run r.terraflow on a very large DEM but I wander if it's
> >>>> __too large__.
> >>>> The region dimensions are:
> >>>> ncol=141114
> >>>> nrow=140487
> >>>> Data type = CELL
> >>>> The map is actually a reclass map of a raster that I imported using
> >>>> r.external.
> >>>> When I run r.terraflow I get:
> >>>> r.terraflow elevation=srtm_brasil at PERMANENT filled=srtm_fill
> >>>> direction=flowdir swatershed=sink accumulation=flowacc tci=srtm_tci
> >>>> directory=E:\terraflow_temp
> >>>> WARNING: raster srtm_brasil is of type CELL_TYPE --you should use
> >>>> r.terraflow.short
> >>>> ERROR: [nrows=140487, ncols=141114] dimension_type overflow -- change
> >>>> (Mon Jan 12 09:57:18 2015) Command finished (0
> >>>> sec)
> >>>> However, I don't have an r.terraflow.short command
> >>>> I'm running Grass 7.0.0beta4 from OsGeo4W
> >>>> Cheers
> >>>> Daniel
> >>>> -------------- next part --------------
> >>>> An HTML attachment was scrubbed...
> >>>> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150112/a27c139f/attachment-0001.html
> >>>> _______________________________________________
> >>>> grass-user mailing list
> >>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> >>>> End of grass-user Digest, Vol 105, Issue 16
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150114/a68dbb5f/attachment.html>
