[GRASS-user] Importing USGS' wrs2_descending Shapefile
Nikos Alexandris
nik at nikosalexandris.net
Wed Jan 14 03:37:14 PST 2015
Nikos Alexandris:
>>> I can't get wrs2_descending.shp file (from
>>> <http://landsat.usgs.gov/documents/wrs2_descending.zip>) to import
>>> sans errors (grass7). No matter the snap threshold. Anyone
>>> recently
>>> imported it?
Markus Neteler wrote:
> I think that their overlapping areas cannot be represented as pure
> topological model.
Right.
> Hence, you need to maintain them (AFAIK it is the -c option in
> v.in.ogr).
> Please correct me if I am wrong.
I'll do so.
> The question is: what's you scope? Visualization?
A complete set of tools for Landsat data, inside GRASS, requires a
proper trimming utility. The existing add-on i.landsat.trim does not
satisfy my needs.
Using a slightly modified version of
<ttps://github.com/robintw/LatLongToWRS>, which I'll integrate into (my
yet-unifinished personal mini-project) <i.landsat.wrs2trim>, one will
simply need to tell which landsat scene(s) (or, optionally, the desired
path & row combination(s)) should be border-pixel-trimmed.
I've decided to go the hardway, meaning, let the user or the script,
get the "wrs2_descending.shp" file, import it in GRASS and let the
module do its work. Or, perhaps, share along with the module a clean
vector data set (in GRASS' native format? compressed?).
Nikos
