[GRASS-user] Question about GRASS raster temporal data
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Sat Jan 17 10:44:32 PST 2015
Hi Thomas,
The "out of the box"- option would be to use
t.vect.observe.strds
However, "r.what" is significantly faster, but requires with > 400 maps a little bit of scripting.
My approach is this one (there you can find a little shell-script:
https://www.mail-archive.com/grass-dev@lists.osgeo.org/msg38802.html
(the "transpose" command i the script is nothing but a little awk-command, like e.g. here: http://stackoverflow.com/questions/13634816/using-awk-to-transpose-column-to-row)
Hopefully there will e some development in that direction soon...
Cheers
Stefan
Von: grass-user-bounces at lists.osgeo.org <grass-user-bounces at lists.osgeo.org> im Auftrag von Thomas Adams <tea3rd at gmail.com>
Gesendet: Samstag, 17. Januar 2015 17:06
An: grass-user at lists.osgeo.org
Betreff: [GRASS-user] Question about GRASS raster temporal data
All:
I am just getting started using GRASS raster temporal data analysis capabilities (both GRASS 7.0 and 7.1svn as of this AM) -- pretty cool, with some nice features. I have looked through the wiki:
http://grasswiki.osgeo.org/wiki/Temporal_data_processing
and saw the use of g.gui.tplot<http://grass.osgeo.org/grass71/manuals/g.gui.tplot.html> which worked for my small data set (see t.info<http://t.info/> output below) -- what I need, however, are the values and dates extracted by g.gui.tplot exported to a text file. How do I get these? I have looked through all the modules and can not find what I need.
Best,
Tom
GRASS 7.0.0beta3 (newster):~/grass/data > t.info<http://t.info/> type=strds input=ann_max_flow
+-------------------- Space Time Raster Dataset -----------------------------+
+-------------------- Basic information -------------------------------------+
| Id: ........................ ann_max_flow at adams
| Name: ...................... ann_max_flow
| Mapset: .................... adams
| Creator: ................... teaiii
| Temporal type: ............. absolute
| Creation time: ............. 2015-01-17 05:28:15.023686
| Modification time:.......... 2015-01-17 05:38:10.846286
| Semantic type:.............. mean
+-------------------- Absolute time -----------------------------------------+
| Start time:................. 1997-01-01 00:00:00
| End time:................... 2014-01-01 00:00:00
| Granularity:................ 1 year
| Temporal type of maps:...... interval
+-------------------- Spatial extent ----------------------------------------+
| North:...................... -4895850.0
| South:...................... -5224462.5
| East:.. .................... 2695575.0
| West:....................... 2424112.5
| Top:........................ 0.0
| Bottom:..................... 0.0
+-------------------- Metadata information ----------------------------------+
| Raster register table:...... raster_map_register_9d88390c739741bbb43e68759f90c4c9
| North-South resolution min:. 4762.499512
| North-South resolution max:. 4762.5
| East-west resolution min:... 4762.499512
| East-west resolution max:... 4762.5
| Minimum value min:.......... 0.209504
| Minimum value max:.......... 2.55081
| Maximum value min:.......... 856.120972
| Maximum value max:.......... 5188.450195
| Aggregation type:........... None
| Number of registered maps:.. 17
| Title:
| Potomac annual maximum flows
| Description:
| Potomac annual maximum flows derived from NOAA/NWS RDHM DHMTF analysis 1996-2013
| Command history:
| # 2015-01-17 05:28:15
| t.create type="strds" temporaltype="absolute"
| output="ann_max_flow" title="Potomac annual maximum flows"
| description="Potomac annual maximum flows derived from NOAA/NWS RDHM DHMTF analysis 1996-2013"
| # 2015-01-17 05:38:10
| t.register -i type="rast" input="ann_max_flow"
| file="potomac_max_flow_list.txt" start="1997-01-01" increment="1 year"
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150117/94df8d7b/attachment-0001.html>
