[GRASS-user] Question about GRASS raster temporal data
Thomas Adams
tea3rd at gmail.com
Sat Jan 17 11:04:24 PST 2015
Stefan,
Thank you for your response -- it looks like I'll have to do a bit of
scripting, which is OK... I just did not want to needlessly re-invent the
wheel. Having such a capability built into the tools is a great idea,
however.
Best,
Tom
On Sat, Jan 17, 2015 at 11:44 AM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hi Thomas,
> The "out of the box"- option would be to use
> t.vect.observe.strds
> However, "r.what" is significantly faster, but requires with > 400 maps
> a little bit of scripting.
> My approach is this one (there you can find a little shell-script:
> https://www.mail-archive.com/grass-dev@lists.osgeo.org/msg38802.html
> (the "transpose" command i the script is nothing but a little
> awk-command, like e.g. here:
> http://stackoverflow.com/questions/13634816/using-awk-to-transpose-column-to-row
> Hopefully there will e some development in that direction soon...
> Cheers
> Stefan
> *Von:* grass-user-bounces at lists.osgeo.org <
> grass-user-bounces at lists.osgeo.org> im Auftrag von Thomas Adams <
> tea3rd at gmail.com>
> *Gesendet:* Samstag, 17. Januar 2015 17:06
> *An:* grass-user at lists.osgeo.org
> *Betreff:* [GRASS-user] Question about GRASS raster temporal data
> All:
> I am just getting started using GRASS raster temporal data analysis
> capabilities (both GRASS 7.0 and 7.1svn as of this AM) -- pretty cool, with
> some nice features. I have looked through the wiki:
> http://grasswiki.osgeo.org/wiki/Temporal_data_processing
> and saw the use of g.gui.tplot
> <http://grass.osgeo.org/grass71/manuals/g.gui.tplot.html> which worked
> for my small data set (see t.info output below) -- what I need, however,
> are the values and dates extracted by g.gui.tplot exported to a text file.
> How do I get these? I have looked through all the modules and can not find
> what I need.
> Best,
> Tom
> GRASS 7.0.0beta3 (newster):~/grass/data > t.info type=strds
> input=ann_max_flow
> +-------------------- Space Time Raster Dataset
> +-------------------- Basic information
> | Id: ........................ ann_max_flow at adams
> | Name: ...................... ann_max_flow
> | Mapset: .................... adams
> | Creator: ................... teaiii
> | Temporal type: ............. absolute
> | Creation time: ............. 2015-01-17 05:28:15.023686
> | Modification time:.......... 2015-01-17 05:38:10.846286
> | Semantic type:.............. mean
> +-------------------- Absolute time
> | Start time:................. 1997-01-01 00:00:00
> | End time:................... 2014-01-01 00:00:00
> | Granularity:................ 1 year
> | Temporal type of maps:...... interval
> +-------------------- Spatial extent
> | North:...................... -4895850.0
> | South:...................... -5224462.5
> | East:.. .................... 2695575.0
> | West:....................... 2424112.5
> | Top:........................ 0.0
> | Bottom:..................... 0.0
> +-------------------- Metadata information
> | Raster register table:......
> raster_map_register_9d88390c739741bbb43e68759f90c4c9
> | North-South resolution min:. 4762.499512
> | North-South resolution max:. 4762.5
> | East-west resolution min:... 4762.499512
> | East-west resolution max:... 4762.5
> | Minimum value min:.......... 0.209504
> | Minimum value max:.......... 2.55081
> | Maximum value min:.......... 856.120972
> | Maximum value max:.......... 5188.450195
> | Aggregation type:........... None
> | Number of registered maps:.. 17
> | Title:
> | Potomac annual maximum flows
> | Description:
> | Potomac annual maximum flows derived from NOAA/NWS RDHM DHMTF analysis
> 1996-2013
> | Command history:
> | # 2015-01-17 05:28:15
> | t.create type="strds" temporaltype="absolute"
> | output="ann_max_flow" title="Potomac annual maximum flows"
> | description="Potomac annual maximum flows derived from NOAA/NWS
> RDHM DHMTF analysis 1996-2013"
> | # 2015-01-17 05:38:10
> | t.register -i type="rast" input="ann_max_flow"
> | file="potomac_max_flow_list.txt" start="1997-01-01" increment="1
> year"
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150117/aae90986/attachment.html>
