[GRASS-user] GRASS/gdal grib2 decoding issue for new NCEP MRMS data
Thomas Adams
tea3rd at gmail.com
Mon Jan 19 20:57:56 PST 2015
All:
I'm not on the gdal-dev at lists.osgeo.org mailing list, so I can not report
this here. NOAA/NCEP is producing new hourly CONUS NEXRAD radar-based
meteorological data -- my interest is precipitation. The data is available
now via a UCAR LDM process, described in the 1st link. The problem is
(using the downloadable sample data), gdal recognizes the data files as
grib2, but it will not decode the data (I have not previously had any
problems). The Google docs file states that there is an issue and points to
an updated wgrib2 that can handle the grib2 decoding (which it does) -- the
second link.
wgrib2 v0.2.0.1 7/2014 Wesley Ebisuzaki, Reinoud Bokhorst, Jaakko Hyvätti,
Dusan Jovic, Kristian Nilssen, Karl Pfeiffer, Pablo Romero, Manfred
Schwarb, Arlindo da Silva, Niklas Sondell, Sergey Varlamov
https://docs.google.com/document/d/1LeVcn_taIXZgzZb5JgWqaVr0xVs7GmA6RpHcb8ZGiwk/edit
http://www.cpc.noaa.gov/products/wesley/wgrib2/
When I used wgrib2 to produce a binary file, I could then import the
example data file into GRASS:
r.info map=MRMS_GaugeCorr_QPE_01H_00.00_20141208_120000 at teaiii
| Map: MRMS_GaugeCorr_QPE_01H_00.00_ Date: Mon Jan 19 20:36:05
2015 |
| Mapset: teaiii Login of Creator:
teaiii |
world_location |
| DataBase:
/home/teaiii/grass/data |
| Title: ( MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000
| Timestamp:
none |
| Type of Map: raster Number of Categories:
0 |
| Data Type:
FCELL |
| Rows:
3500 |
| Columns:
7000 |
| Total Cells:
24500000 |
| Projection:
Latitude-Longitude |
| N: 55N S: 20N Res:
0:00:36 |
| E: 60W W: 130W Res:
0:00:36 |
| Range of data: min = 0 max =
210.5 |
| Data
Description: |
| generated by
r.in.bin |
Comments: |
| r.in.bin -f
input="/home/teaiii/Downloads/MRMS_GRIB2_SAMPLE-precip/t\ |
| est.bin" output="MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000"
bytes\ |
| =4 header=8 bands=1 order="native" north=55 south=20 east=-60
west=-\ |
| 130 rows=3500 cols=7000 anull=-3
flip="v" |
So, I thought the community would be interested in (1) knowing about the
data and (2) the GRASS/gdal decoding issue.
Cheers!
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150119/2ce8984c/attachment.html>
