[GRASS-user] grass-user Digest, Vol 105, Issue 36
Maci Edwards edwards.maci at gmail.com
Tue Jan 20 13:54:25 PST 2015
Please unsubscribe me. Thank you!
On Tue, Jan 20, 2015 at 2:00 PM, <grass-user-request at lists.osgeo.org> wrote:
> Send grass-user mailing list submissions to
>         grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. GRASS/gdal grib2 decoding issue for new NCEP MRMS data
>       (Thomas Adams)
>    2. Re: Large Grass Raster Notes (Markus Neteler)
>    3. Re: Large Grass Raster Notes (Vaclav Petras)
> Message: 1
> Date: Mon, 19 Jan 2015 21:57:56 -0700
> From: Thomas Adams <tea3rd at gmail.com>
> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] GRASS/gdal grib2 decoding issue for new NCEP
>         MRMS data
> Message-ID:
> CAGxgkWjUL+LMHcV9EB013KGUAyhLnvcT2b-xMNGiSDw-GAHVFw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> All:
> I'm not on the gdal-dev at lists.osgeo.org mailing list, so I can not report
> this here. NOAA/NCEP is producing new hourly CONUS NEXRAD radar-based
> meteorological data -- my interest is precipitation. The data is available
> now via a UCAR LDM process, described in the 1st link. The problem is
> (using the downloadable sample data), gdal recognizes the data files as
> grib2, but it will not decode the data (I have not previously had any
> problems). The Google docs file states that there is an issue and points to
> an updated wgrib2 that can handle the grib2 decoding (which it does) -- the
> second link.
> wgrib2 v0.2.0.1 7/2014 Wesley Ebisuzaki, Reinoud Bokhorst, Jaakko Hyv?tti,
> Dusan Jovic, Kristian Nilssen, Karl Pfeiffer, Pablo Romero, Manfred
> Schwarb, Arlindo da Silva, Niklas Sondell, Sergey Varlamov
> https://docs.google.com/document/d/1LeVcn_taIXZgzZb5JgWqaVr0xVs7GmA6RpHcb8ZGiwk/edit
> http://www.cpc.noaa.gov/products/wesley/wgrib2/
> When I used wgrib2 to produce a binary file, I could then import the
> example data file into GRASS:
> r.info map=MRMS_GaugeCorr_QPE_01H_00.00_20141208_120000 at teaiii
>  | Map:      MRMS_GaugeCorr_QPE_01H_00.00_  Date: Mon Jan 19 20:36:05
> 2015    |
>  | Mapset:   teaiii                         Login of Creator:
> teaiii          |
>  | Location:
> world_location                                                   |
>  | DataBase:
> /home/teaiii/grass/data                                          |
>  | Title:     ( MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000
>  | Timestamp:
> none                                                            |
>  |   Type of Map:  raster               Number of Categories:
> 0               |
>  |   Data Type:
> FCELL                                                      |
>  |   Rows:
> 3500                                                       |
>  |   Columns:
> 7000                                                       |
>  |   Total Cells:
> 24500000                                                   |
>  |        Projection:
> Latitude-Longitude                                      |
>  |            N:        55N    S:        20N   Res:
> 0:00:36                   |
>  |            E:        60W    W:       130W   Res:
> 0:00:36                   |
>  |   Range of data:    min = 0  max =
> 210.5                                   |
>  |   Data
> Description:                                                        |
>  |    generated by
> r.in.bin                                                   |
> Comments:        |
>  |    r.in.bin -f
> input="/home/teaiii/Downloads/MRMS_GRIB2_SAMPLE-precip/t\   |
>  |    est.bin" output="MRMS_GaugeCorr_QPE_01H_00.00_20141208-120000"
> bytes\   |
>  |    =4 header=8 bands=1 order="native" north=55 south=20 east=-60
> west=-\   |
>  |    130 rows=3500 cols=7000 anull=-3
> flip="v"                               |
> So, I thought the community would be interested in (1) knowing about the
> data and (2) the GRASS/gdal decoding issue.
> Cheers!
> Tom
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150119/2ce8984c/attachment-0001.html
> Message: 2
> Date: Tue, 20 Jan 2015 17:35:48 +0100
> From: Markus Neteler <neteler at osgeo.org>
> To: Jeshua Lacock <jeshua at 3dtopo.com>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] Large Grass Raster Notes
> Message-ID:
>         <CALFmHhuKm1=
> xmcvDkOVa2vGZnwVC_ZAx7PLh7GxSqebBNVX8cA at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> On Sun, Jan 18, 2015 at 1:00 AM, Jeshua Lacock <jeshua at 3dtopo.com> wrote:
> > Greetings,
> > In the event my experience working with rather large GRASS rasters may
> be useful, I thought I would share it. The following notes were compiled
> running the  GRASS 7.0.0beta4-141230 package on Mac OS X 10.10.1. The
> system is a 6-core Xeon with 32GB of RAM, running in full 64-bit mode.
> > 1. Using an r.external virtual mosaic as the input proved impossible
> trying to run r.resample on it on trying to produce a nearly teracell
> raster (I ended up breaking sub-tiles). I closely followed the instructions
> on the Wiki.
> > 2. On smaller sub-tiles of said image, r.resample was insanely slow even
> with the external imagery.
> You may check/benchmark the other resampling modules, some of them may
> be more modern (ideally faster):
> http://grass.osgeo.org/grass70/manuals/keywords.html#resample
> In case you try, please share the outcome.
> cheers,
> Markus
> Message: 3
> Date: Tue, 20 Jan 2015 14:04:05 -0500
> From: Vaclav Petras <wenzeslaus at gmail.com>
> Message-ID:
> CABo5uVsfKnMC3O+-g+kdK-yj4-29yhBLzvryTFeQrOL9VgPuaw at mail.gmail.com>
> On Sun, Jan 18, 2015 at 1:03 PM, Jeshua Lacock <jeshua at 3dtopo.com> wrote:
> > Actually, I misspoke, the wildcard will not work with long lists either
> as
> > it will crash with some kind argument too long message as well.
> This is strange, the wild card is interpreted inside the module, so the
> argument list shouldn't be too long. If you don't quite the pattern the
> shell can do the expansion but this is not what you want.
> Correct:
> g.remove ... pattern="landsat_*"
> Incorrect:
> g.remove ... pattern=landsat_*
> The later will transform the command line to:
> g.remove ... pattern=landsat_01 landsat_02 landsat_03 landsat_04 ...
> in case you are in directory with files or directories named landsat_01,
> landsat_02, landsat_03, ...
> What is the message you get? And what is the command return code (do echo
> $? to find out)?
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150120/6678f2d5/attachment-0001.html
> End of grass-user Digest, Vol 105, Issue 36
Desire can be of greater import than utility; experience more important
than closure.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150120/79d76911/attachment.html>
